Need some info on "how to do a compression test and leak down test, on an LS1/ HELP!
Thanks
Roger.
1. Rent or buy the leak down tester and compressed air source.
2. Warm the car up to operating temp.
3. Turn off car.
4. Pull all spark plugs.
5. Thread leak down tester to into a spark plug hole.
6. Connect comprerssed air to leak down tester. (90 PSI is good enough)
7. Turn hand crank engine until cylinder you are threaded into is at TDC on compression stroke. (TDC will be the point where leak is the least amount on the gauge)
8. Record percentage of leak on that cylinder.
9. Find source of leak. Take off oil fill cap off and feel for air coming out of the oil filler neck, if air is coming out here your piston rings are worn. Listen and feel the tailpipes for air coming out the exhaust, this indicates leaking exhaust valves. Pop your airlid off and listen and feel for air coming out of the intake manifold, this indicates leaking intake valves.
10. repeat again for all cylinders.
11. Fix sources of leaks.
Google "leak down test" and you will gets lots of articles with pics on this too.
Absolutely, if the engine is staying in the car then listen to Brad. Mine is completely apart at the moment so I just thought I'd throw out my 2 cents on what I did with the heads out. Trending Topics
