tr230/224 and milled heads
Old Oct 10, 2002 | 02:54 PM
Sears's Avatar
!Dial-up Director
Default Re: tr230/224 and milled heads
FWIW, I have TR230, GTP 5.3L heads milled .015, 7.4 pushrods. No piston/valve clearence issues.
Justin
Old Oct 10, 2002 | 03:35 PM
BYBYC5's Avatar
*Bad Trader*
How much diffrence are the 5.3 than the 5.7s as far ad milling?.015 on 5.3s would not be the same as .015 on 5.7s?
Old Oct 10, 2002 | 04:01 PM
Dave@Ramchargers's Avatar
You cant really compare the 5.3 to the 5.7's in this case.
depending on cc, and valves etc.
I wished i had an answer for you as im looking into this myself. short of checking the actual piston to valve clearence i have im SOL.
but you can not go by what guys are saying unless they have the exact setup you have with the same head.
<small>[ October 10, 2002, 04:26 PM: Message edited by: Dave@Ramchargers ]</small>
Old Oct 10, 2002 | 04:19 PM
Jason99T/A's Avatar
I can shift faster than you.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Grinch:
<strong>.015 on 5.3s would not be the same as .015 on 5.7s?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Clearance should be the same, assuming the heads are cut identical and the valves are the same,etc.
Old Oct 10, 2002 | 05:00 PM
BYBYC5's Avatar
*Bad Trader*
but my original question still stands. can imill .030 off of 5.7s and still be ok with the 230 cam??
Old Oct 10, 2002 | 05:09 PM
Damian's Avatar
LSX Mechanic
<strong>but my original question still stands. can imill .030 off of 5.7s and still be ok with the 230 cam??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Patrick G on the board has his 5.7 heads milled more than .030 with the TR230 cam and he has no problems....
Old Oct 10, 2002 | 05:12 PM
Sears's Avatar
!Dial-up Director
I believe he has valve reliefs in the pistons and larger valves.
Old Oct 11, 2002 | 12:18 AM
BYBYC5's Avatar
*Bad Trader*
Default tr230/224 and milled heads
i lost track of the conversation a while back. will tr230/224 fit with 5.7s milled .030, .025,etc.....and what pushrods.....
