Need some Cylinder head opinions
I was sold on AFR because of the nice flow numbers and the quality of the CNC work and the price isnt horrible. But maybe I was just sold on the name?
I checked out ET performance just now and it looks like they have some KILLER heads. their 225 flows 8 cfm more than the AFR plus they go all the way to 255!
I dont think i need that much cylinder head yet but its there at least.I am going for around 11.5:1 cam I am uncertain but it looks like guys are having good results with cams in the mid .600 lift area with high 230 low 240 duration on a smaller(108) lobe from what i can see. Comps biggest cam the off the shelver is around there, but maybe ill have one ground.
fast 90/90 on top aeromotive fuel system, kooks headers. Im going 4l85e from FLT with a Coan precision built converter.
My goal is around 550 or more RWHP, im gunna need it because I got a full weight hawk with a 6pt and I dont wanna gut this thing its too nice.
this is street and strip. But now I ask you guys, which cylinder head do you recommend? They both seem to have bad *** heads, are their other manufacturers or CNC companies out there making better ones?
Thanks for the help guys.
And I dont want canted valve heads, although it would be bad ***...
And right Now im looking into the TEA Ported 225 tfs heads, they will be getting a call tomorow.
As well as Patriot and Et Performance. I want the best head for my motor Im checking all sources.
https://ls1tech.com/forums/dynamometer-results-comparisons/677365-updated-results-our-416-trickflow-stroker.html
Re-ported ET 245’s
https://ls1tech.com/forums/dynamometer-results-comparisons/662627-408-et-245-s-dyno-graph.html
There is far more to making power with heads than flow numbers on a flow bench
I just had a customer with a C6 Vette LS2 stock shortblock go from a LPE LS6 Stg 3 head with 11.5:1 compression to the TFS 225 with 12:1 compression. With the new TFS heads the MAF readings showed less airflow through the engine, the engine had no detonation, where it did before with the LS6 heads, and made 27 more RWHP for a total of 507 RWHP...did I mention there is far more to heads than flow numbers on a flow bench?
511 rwhp plus 455 rwtq.
Total drivability...
Great power down low!!!
I rev the engine to 7300 rpm + when needed, but power is there already at 3000 rpm...
On a practical side, the 11 degree valve angle gives you an amazing amount of PtV clereance.
You can use a HUGE cam without flycutting!!!
The insert in the heads are a technical plus...
Just facts that I report, good luck with your choice and have good power
Christian
Christian
