Rocker arm ratio changes net more power?
Old Mar 23, 2007 | 10:02 PM
1hotls1's Avatar
Default Rocker arm ratio changes net more power?
I've read alot of threads on the use of 1.8 rockers and just wondered if any of you valvetrain specialists might have an opinion about their use. My car's power curve is just where I need it to be and am curious if these would net me a little more power instead of going to a larger cam. My current cam is 218/221 and .526"/.534". Will it be worth the trouble or do I need to just go bigger cam?
Old Mar 23, 2007 | 10:04 PM
brad8266's Avatar
I wouldnt buy new rockers for a power gain, i would buy them as a stability mod though since a good aftermarket rocker set is a lot better than the stockers.
Old Mar 23, 2007 | 11:02 PM
HEMIETR's Avatar
I don't like to use rockers to replace what should be done with a cam.
Old Mar 23, 2007 | 11:07 PM
5_02ls1's Avatar
going from 1.7s to 1.8s you will gain.030 lift.+better stability as stated above.id install betterv valvesprings and pushrods as well.
Old Mar 24, 2007 | 12:12 PM
JPH's Avatar
JPH
if you put crane cams 1.8 quick lifts on it, you will diffently see a gain.
Old Mar 24, 2007 | 09:31 PM
mrr23's Avatar
yes, using the correct rockers will net you more power.
worth it is up to you. i say yes, as i use the vinci/crane accelerated lift rockers with great success. you end up with more power in the same rpm range that you are in.
here's a dyno comparing stock rockers to the 1.8 accelerated rockers.
Old Mar 24, 2007 | 10:45 PM
lovescamaros28's Avatar
multiply cam lobe lift by rocker ratio and you come up with valve lift,so obviously you are going to get more lift and power with a 1.8:1 rocker.
Old Mar 26, 2007 | 09:05 PM
1hotls1's Avatar
Any idea how much power you can gain from this swap in a mild cam car? I don't know if I want to do this or just go for the bigger cam. It would definitely be easier to do than a cam swap.
Old Mar 27, 2007 | 12:44 PM
CODE4LS1's Avatar
Don't mean to hijack, but how much more lift and duration with a 1.75 rocker? I have a MTI C2, .224/.224 .581/.581 112 LSA, and am thinking of getting a set before a tune.
Old Mar 28, 2007 | 08:44 AM
1hotls1's Avatar
I don't think that they can affect duration but your lift will definitely increase. If your stockers are 1.7, your new lift will be .598 I think. I'm sure someone with more knowledge about these can correct this if I'm wrong.
Old Mar 28, 2007 | 10:38 AM
CODE4LS1's Avatar
I always thought that if your lift would increase due to the higher ratio, you would also get at least a couple more degrees of duration....maybe someone can chime in and correct me if im wrong.
Old Mar 28, 2007 | 10:40 AM
JPH's Avatar
JPH
correct. not much, but yes.
Old Mar 28, 2007 | 05:45 PM
mrr23's Avatar
technically, you don't get any more cam duration as that is ground into the cam. the valve still open and close at the same exact events. cam durations are measured at .004, .050, and .200 lift, most commonly. with a higher ratio, these lift numbers come sooner in the valve events. so, you get an 'effective' increase of duration at the valve. this is called valve duration. and that's what the motor cares about, what happens at the valve.
Old Mar 28, 2007 | 07:35 PM
JPH's Avatar
JPH
+1 for this answer.
Old Mar 29, 2007 | 01:58 AM
CODE4LS1's Avatar
Thx for the replies. Decided not to go with the 1.75's after all. Big help, I appreciate it.
