stock 6.0 block and GM CNC LS6 heads, what cr?
Well the LQ4 (Chevy/GMC) is like 9.4/9.5:1 compression, and the LQ9 (Caddy) is 10.0:1. But w/ those ported heads, im not sure what the compression would be...you could get whatever compression pistons you want tho, i bet from some place
umm.
Thats a little more than i was looking for <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> would like to stay close to stock, and these 2 parts looked like they might have worked good together, and fairly cost effective.
I know i could build a motor for whatever i wanted, and may do that many years down the line. But can't afford to at that time.
But is 10.8:1 alright for a daily driver? or a little too high, Florida, its hot, and 93 octane.
Ryan.
Ryan.
10.8:1 is a fine CR for the street. just dont be using that plus 89 octane. ;D 93 or better and you'll be fine. aside from that w/ the bigger bore you should be able to put down some really good numbers with that setup. happy rodding,
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
A standard 6 liter block has dished pistons and is a 9.4:1 compression. The LS6 head will be about 6 cc less than the stock heads. I didn't calculate it out, but it wont be anything near 10.8:1, probably more like 10.2:1, unless the LS6 heads have been milled. I didn't take the time to calculate it, someone will and give you an exact number.
unfortunately, the only way the heads come CNC ported, and with valves is milled <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
you can buy a bare set, and add the valves..ect. but the 02 LS6 valves are a pretty penny when buying parts piece by piece.
Ryan
Ryan
