Dyno sheet for TR220/114 cam and bolt ons - suprised
The complete list is:
SLP lid
Holley filter
Fast Toys plastic MAF ends
SLP smooth bellows
S2 ported throttle body
Throttle body coolant bypass
FLP long tube headers
Hooker catback
TR220°/.561"/114° cam
Chrome moly pushrods
Comp Cams Titanium retainers
Comp Cams 26918 springs
ASP 25% underdrive crank pulley
Lou's short stick on stock Hurst
180° thermostat
MSD 8.5mm plug wires
AMS custom tuning (LS1 Edit)
SLP lid
Holley filter
SLP smooth bellows
Hooker catback
180° thermostat
Nice nice numbers givin stock heads!
I just purchased a TR-220
BTW, that TR-220 was advertised incorrectly on the Thunder web site. Its actually .553" lift
There web site now reflects the correct lift #.
BTW, do you believe your "ported" TB added any power? I was thinking of purchasing one, but they have the exact same throttle plate size as stock. I keep saying they should call them "smoothed" and not ported. Anyway, are they really worth the bucks in your opinion?
Thanks,
Ron
Thanks,
Ron
Bret Bauer over on LS1.Com was pretty convincing that these ported TBs do in fact make some power. Maybe he is right.
Again, are you happy with yours?
Ron,
Ron,
To be honest I didn't dyno before and after the TB, and I couldn't tell for sure if it pulled any harder. It did however change the throttle response and low rpm driveability. TR was sharper, and the darn thing will not load up or shudder if you let the rpms drop. It drives fine at 50 mph in sixth (stock 3.42 rear) after the TB. So I don't know for sure, but comparing stock and S2 side by side, it sure looks like the S2 would cause far less turbulence. I saw a post from someone last night that had an '01 M6 with the exact same mods that I have except for the S2 and pulley, and he dyno'd 370. I would spend the money over again.
Kimchee and Rice is corrent, the cam card says .553.
K & R .. The ported TB's really are ported. There is a ridge just before the throttle blade that gets hogged out. I did my own, using the coffee stirrer as a template. When you get done,and the coffee stirrer goes thru the ported one & then try it on a stock one, you can really see just how much they are ported. As for HP, I don't know but it can't hurt & it definately improves throttle response.
I wish a set of heads were in the budget, but I have spent my toy money for a while. I am very happy with the way it pulls now <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Gary98Z - According to Thunder the 224 cam will make about 10 hp more from 5K up, and I presume it would give up a little below 2500. The 220 cam is extremely driveable, basically around town it drives like stock with a slightly more choppy idle. No codes with stock tuning either.
