Comp Cams 222/.563 114... Advance ground in?
I am about to have a cam installed. Does anybody know if this cam (Comp Cams 222/.563 114) has advance ground in?
Thanks,
Kyung
<small>[ November 12, 2002, 07:14 PM: Message edited by: bae_98Z ]</small>
Thanks,
Kyung
Re: Comp Cams 222/.563 114... Advance ground in?
That lift is not an XE-R lobe, more like an XE. The only person who knows what the ICL is of that cam is the person with the cam card since its ground to specs.
I have the cam card. It says 114 ICL. That means no advance, eh?
I want peak power at about 6000RPM, should I advance the cam 4 degrees?
Kyung
<small>[ November 12, 2002, 07:15 PM: Message edited by: bae_98Z ]</small>
Kyung
Well, if the cam card says 114 LSA and 114 IC, there is no advance ground-in.
If that is the case, advancing it 4 degrees during installation will get you a little better throttle response, better low end torque, with a slight loss of HP at high revs.
Brings the whole HP/Torque curve down a little with a slight loss of HP at max RPM (limits rpm slightly). In my opinion, I would not go any farther than 4 degrees [total] advance on the cam.
At least, this is the way I understand it.
Ron,
Ron,
I have that cam, installed dot to dot (by Mikey).. here's the cam card:
<img src="http://www.jailhouse-diary.com/camcard1.jpg" alt=" - " />
