Discussion on Darton sleeves being used by Cartek and LPE.
Old 11-19-2002, 07:17 PM
  #61
qqwqeqwrqwqtq's Avatar
Default Re: Discussion on Darton sleeves being used by Cartek and LPE.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nickn20:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by INTMD8:
<strong>Would it be possible to use these sleeves in an LT1 block? If so, what would be the largest possible bore diameter?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">no your block is iron, sleeves are for aluminum. all you have to do is bore your block, which is much cheaper.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The max safe bore on an LT1 is 4.04-4.05. I was interested in using these sleeves with a 4.125 bore.
Old 11-19-2002, 10:36 PM
  #62
SIR
SIR's Avatar
Ed:
Keep us posted when Darton releases the 4.155 sleeve.
Old 11-21-2002, 12:07 AM
  #63
SIR
SIR's Avatar
Are ARE,LPE and Cartek using the same or very similar process for getting the 4.125 resleeve with the Darton????
I am getting a good range of prices for the 4.125 resleeve, with ARE (like $400 lower..exhcange rates??)coming in on the lows and Cartek on the highs. LPE surprisingly in the middle.
Old 11-21-2002, 07:59 AM
  #64
Closed ex-Sponsor Account
Ed Potter @ LPE's Avatar
SIR -
I checked on the 4.155" sleeve yesterday and found out we can do them now! it will still take 2 weeks to order them, but if you want to do a 4.155 block, we can do one for you now. As far as I know, our process is the same as Cartek, but ARE says theirs is different. Call me if you're interested.
Ed
Quick Reply: Discussion on Darton sleeves being used by Cartek and LPE.
