How much HP gain going to 02 Z06 Cam from stock cam on a bolt on motor?
Ive got a 98 ss camaro motor, MAC headers, SLP MAF, ported TB, ls6 intake, 200 shot nitrous, asp underdrive pulley, ls1 edit software (this is swapped into a 2700lb full weight 91 corvette)
What kind of horsepower gains would i be looking at with a 02' Z06 cam over the stock cam? I really dont have the $400 to throw down on a TR230 cam, but i can get this one for $100.
6600 rpm clutch dump of death Administrator
Re: How much HP gain going to 02 Z06 Cam from stock cam on a bolt on motor?
It going to cost more than $100. The Z06 cam has a smaller base circle. So you will need pushrods.
Also on the Z06 has springs that are stronger than a stock LS1.
The Z06 valves are also longer than the stock LS1 valves.
So, you have almost as much cost as putting in an aftermarket cam getting your springs and such squared away.
<small>[ November 15, 2002, 09:33 PM: Message edited by: J-Rod ]</small>
Actually the difference in the base circle is only .7MM, which equates out to .35MM in radius, which is what matters. Thats appx. .15" (on the high side). The stock pushrod length is 7.395. So technically to get the geometry back exactly where it was, you would need pushrods 7.545" in length. Ive been told by many tuners that have installed this cam that the difference in the base circle can be made up by the lifter itself. You should replace your pushrods anyway, and most aftermarket pushrods are 7.40" You can go ahead and order them longer, or just let the lifter soak up the difference. I'll post my dyno results as soon as I get it done. Im going to use the 7.40" pushrods I already have from my other car.
jay 95 is right. while dynoing my ride, a guy dynoed the 02-zo6 cam 19.8 rwhp was his improvement.with his boltons if i remember he was in the 370-380 rwhp range.i would go with something alittle bigger. goodluck.
How much should I gain with a '01 LS6 cam over a stock LS1 cam? I will have Mac Headers, Ypipe (gutted cats), Hooker Catback, S2 TB, Lid, and possibly an LS6 Intake. Will I need different pushrods w/ the '01 LS6 cam?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by James1:
<strong>How much should I gain with a '01 LS6 cam over a stock LS1 cam? I will have Mac Headers, Ypipe (gutted cats), Hooker Catback, S2 TB, Lid, and possibly an LS6 Intake. Will I need different pushrods w/ the '01 LS6 cam?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Peak rwhp will go up about 10-15 rwhp,but it will be pushed further up the rpm range (mine went from 5400 to 5800 rpms). More importantly the hp curve will stay nearly flat from 5800 to 6300 rpms, compared to the stock hp curve tapering down after 5400 rpms.
Stock LS1 pushrods work fine with 01 cam.
Hope this helps.
<small>[ November 17, 2002, 10:50 AM: Message edited by: BLKTA ]</small>
Hope this helps.
