need advice on a cam/heads setup
Old Apr 4, 2007 | 12:20 PM
86MonteSS's Avatar
Default need advice on a cam/heads setup
i'm looking for mid 400's in horse to the wheels. over 400 torque to the wheels. and a DD (6-speed)
any recommendations?
Old Apr 4, 2007 | 01:42 PM
86MonteSS's Avatar
anyone?
Old Apr 4, 2007 | 01:53 PM
98Z28MASS's Avatar
Hmmmmm for mid 400 rwhp and 400 rwtq on a DD youd need some milled afr 205's, say maybe a 230/230 ish cam, ported fast 90/90, LT's, duals and a tune
Old Apr 4, 2007 | 01:55 PM
98Z28MASS's Avatar
add a 25% pulley on that list too
Old Apr 5, 2007 | 07:07 PM
86MonteSS's Avatar
sounds good! anyone else have any recommendations before i go shopping?
Old Apr 5, 2007 | 07:13 PM
JASON11WS6's Avatar
If your talking 450 in a ls1 it's not an easy task. Especially if you want it to be a daily driver. Anyway that being the case it's going to take a lot of came and some real good heads. AFR's are a good choice, so are Trick Flow's. Your going to have to mill them pretty good to get the compression up and you'll definatley need all the bolt ons you can get. Should be easier to do with a 6speed though.
Old Apr 5, 2007 | 07:21 PM
quick346's Avatar
well this is my mod list should get you close AFR's 205 ,224/228 cam the heads are milled to 59cc and i am running the fast 90/90 i will have dyno numbers in two weeks.
should be 440 rwhp range or a little better i think.and will still be a nice driver with the 3500 converter
the cost was ah little hard to swallow but once done and running i wil forget about that real fast!!!!
Old Apr 13, 2007 | 09:48 PM
86MonteSS's Avatar
let me know how it goes. that fast 90/90 set up must have hurt your pocket
Old Apr 14, 2007 | 12:21 PM
darrensls1's Avatar
The cam is a little on the small side and a 3500 stall means you have an automatic. I just don't see 440 rwhp through a street cam, automatic and 3500 stall. My guess is you'll dyno closer to 400. If I'm right don't be too disappointed because what we autos lack on the dyno we more then make up for at the track in ET
86MonteSS,
I would consider ETP 215 heads, decent size cam (232/232 112 or bigger) and a fast 90/90 setup. Of course it goes without saying that you'll need all the bolt-ons including the underdrive pulley and a great dyno tune.
I could see 440+ rwhp from that setup. Of course the 10 bolt might go boom soon after but that's just part of the fun of owning an M6 F-body
Good luck.
Old Apr 14, 2007 | 12:32 PM
blkZ28spt's Avatar
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/361959-so-you-wanna-fast.html
Notice those are all stickies. There are other usefull stickies as well. Good placel to start.
Old Apr 14, 2007 | 08:58 PM
02silvaZ's Avatar
some patriot LS6 stage 3's and a 232/236 cam at least
Old Apr 14, 2007 | 09:31 PM
JF-WS6's Avatar
Read my sig. Its not a DD for me, but it could be,its very street friendly
Old Apr 14, 2007 | 09:53 PM
Phil'sC5vette's Avatar
see sig
Old Apr 14, 2007 | 10:09 PM
mochiles's Avatar
See sig. My heads were custom ported but are very close to TEA 5.3s. I love the F13 for a DD cam. 90/90 does hurt the pockets but you have to pay to play.
Old Apr 14, 2007 | 10:17 PM
86MonteSS's Avatar
thanks guy! awesome info!!!
Old Apr 14, 2007 | 10:24 PM
I dont DD mine, but I wouldnt have a problem doing it.
Drives fine, but It my weekend get away car.
Old Apr 16, 2007 | 10:09 AM
98Z28MASS's Avatar
Saying Daily Driver is tough though as some people can only deal with driving a 224/224 max while others daily drive t-rex cams. The smaller the cam the more money youir going to have to spend to get to mid 400's rwhp. That means ported fast 90/90 combo, 25% pulley, a badass set of milled heads to up the compression, and the cam of your choice. FWIW my 232/238 cam was very easily daily driven.
