Lighter Alum ATI Super Damper affect on engine?
What would all of the effects be of a lighter Aluminum ATI Super Damper on our LS1 engine? Let's say OEM size damper. 2.5# lighter than stock.
Rev Faster?
Less bearing wear?
Longer engine/crank/bearing life?
Stronger damper, less chance of coming apart?
Effects in low and mid RPM's? They said it was designed for the LS1 power band and engine. I forget benefits, but they show from 3k+ supposedly.
Reasons it'd be better for a Supercharged car?
Minimal if any HP gains?
Would less rotating weight cause an MN6 to bog more on the launch similar to an aluminum flywheel?
Any +/- I've missed?
Rev Faster?
Less bearing wear?
Re: Lighter Alum ATI Super Damper affect on engine?
Some data:
http://www.atiperformanceproducts.co...rs/dampers.htm
Shows comparison vs. other high-end dampers but doesn't show it's superiority from 2k rpm+ vs. the OEM damper. Wish we had that comparison.
<small>[ November 20, 2002, 08:14 PM: Message edited by: MelloYellow ]</small>
Looks to me like the fluidamper does a better job stopping vibration. The ATI is worse than the fluidamper from 5900-6900rpms, and only beats the competition above 7000rpms, which is above the rpm range most of our cars operate at.
How about:
Why does the NHRA care? Safety?
Bearing life vs. stock damper?
Engine life vs. stock damper?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
<strong>Looks to me like the fluidamper does a better job stopping vibration. The ATI is worse than the fluidamper from 5900-6900rpms, and only beats the competition above 7000rpms, which is above the rpm range most of our cars operate at.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Problem is no Fluidamper for the LS1. That's too bad because they really do have the best ones out there.
Bret
Bret
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SStrokerAce:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
Bret</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">There is a fluidamper for LS1's.
http://cgi.aol.ebay.com/ebaymotors/w...tem=1872738170
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PewterEllis1:
http://cgi.aol.ebay.com/ebaymotors/w...tem=1872738170</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Direct from http://www.fluidampr.com
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Caveat Emptor, or Buyer Beware...
Don't be fooled by cheap foreign copies that look a little like FluidamprŽ or StreetdamprŽ and are even advertised as "Fluid Damper". These imitations are not manufactured to Vibratech's exacting tolerances and are not backed by Vibratech's exclusive money back guarantee.
Vibratech's evaluation of these viscous damper imitations has shown an inadequate fluid fill, making imitations less than effective at controlling crankshaft vibration. They are inappropriately packaged, which could cause damage in transit and rusting. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Caveat emptor, like they say.
Andrew
Andrew
I saw Fluid Damper at SEMA and got on their *** to make an LS1 damper, they said they would do it and took my name and number down for reference, they said their old boss didn't want to start any new projects thats why the delay, he's gone and the new boss says YES, hopefully they get it done soon...will post if I hear anything
I wonder about the quality of the one in the eBay auction. I realize that it's not a true Fluidamper, but according to the description, it is SFI approved, and not just anything can get an SFI sticker on it.
This may be a less expensive alternative to the ATI unit... Maybe not...
<strong>There is a fluidamper for LS1's.
http://cgi.aol.ebay.com/ebaymotors/w...tem=1872738170</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You gotta watch out...thats a Fluid Damper, and not a Fluidamper. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
