Does "Stock" 02 LS6 Heads?
This is straight from www.Chevrolet.com:
Engine Specifications Z06
Order Code LS6
Type Overhead-valve (OHV)
Pushrod V8
Displacement 5.7L/5665 cc
Fuel Induction System Sequential Fuel Injection
Horsepower (SAE net @ RPM) 405 @ 6000
Torque (lb.–ft. @ RPM) 400 lb.-ft. @ 4800 (manual)
Redline (RPM) 6500
Fuel Shutoff RPM 6600
Compression Ratio 10.5:1
Order Code LS6
Pushrod V8
Redline (RPM) 6500
I had heard the 10.8 previously as well.. I'm thinking that the 02 heads have a slightly larger chamber. That's too bad for folks wanting to bump their compression... It makes it even harder to justify them over the 5.3/5.7 heads.
Thanks Gentlemen, .5 sounds ok, was hoping for a bit more, I would prefer 10.8 to 11.
Are there any availabe gaskets that could help me get to 11. ? as I dont plan to get any work done on them at this time as I am not sure how Mild or Wild yet. (considering using TR 227/224 114 and stock ls6 heads)for now.Im trying to stay mild enough for Isky springs stability without going to Rev duals yet. any thoughts welcome.
