What is our stock cc volume?
Old Dec 4, 2001 | 07:16 PM
jhelms's Avatar
Default What is our stock cc volume?
What is our stock combustion chamber volume?
And does that number change if you have ported and polished heads?
thanks,
Old Dec 5, 2001 | 02:29 PM
Playdough's Avatar
Default Re: What is our stock cc volume?
Speed, Do stock 6.0L heads bolt right on to a stock 5.7L?
Old Dec 5, 2001 | 08:05 PM
jhelms's Avatar
So I'm guessing my ported heads should be somewhere near the mid 60cc region?
Old Dec 6, 2001 | 12:15 AM
Speed Demon's Avatar
John,
I believe Wizkid posted stock chanber cc to be 67.3.
Most ported heads are milled 0.030.
I have read that 60cc is around 11 to 1 CR and
63-64cc is @ 10.6 to 1.
Try doing a search. Someone I'm sure has an excel spreadsheet for calc. chamber volume vs. CR.
If you are planning on going with some boost, you may want to try a set of 6.0L truck heads. They have larger chambers than the stock 5.7 heads and would drop you CR some to allow for more safe boost.
I hope this helps some.
Brandon
Old Dec 6, 2001 | 08:43 AM
Playdough,
The 6.0L heads are supposed to bolt right on to the LS1 block. That's the general consensus. I sure hope so since I have a set sitting in my garage.
The 6.0L heads have revised ports (better flowing) and larger chambers than the 5.7s.
Do a search for "6.0L" or "truck heads". There is a lot of info on the boards.
John,
I would assume your heads are in the low 60cc range, if they milled them 0.030 in.
Old Dec 6, 2001 | 10:21 AM
horsepower's Avatar
[quote]Originally posted by Speed Demon:
<strong>John,
Brandon</strong><hr></blockquote>
To calculate *New* compression ratio from a changed combusion chamber size:
(for STOCK LS1 displacement)
1 - add 10.484 to the cyl head comb. chamber size
2 - add 708.3096 to the number from step 1
3 - divide the number from 2, by the number in 1
example:
60 cc cylinder heads
step 1: 60 + 10.484 = 70.484
step 2: 708.3096 + 70.484 = 778.7936
step 3: 778.7936 / 70.484 = 11.05
(for 382 displacement)
same steps, use 782.4823 instead of 708.3096
Remember, this is all static compression, depending on the cam you choose, your dynamic compression can vary significantly.
-brian
(note, this is based off a 67.4 cc stock chamber only. For another head size (ie, 67.3), just subtract it from 77.8835 to get the addition number in step 1. Example, 77.8835-67.3=10.58)
[ December 06, 2001: Message edited by: horsepower ]</p>
Old Dec 6, 2001 | 11:16 AM
wizkid's Avatar
Install Director
Considering everything is stock but the combustion chamber volume.
Combustion Chamber Volume (cc)-- Static Compression Ratio
60 11 :1
61 10.9 :1
62 10.75 :1
63 10.6 :1
64 10.5 :1
65 10.4 :1
66 10.25 :1
67.3 10.1 :1
ERic
Old Dec 6, 2001 | 11:21 AM
wizkid's Avatar
Install Director
[quote]Originally posted by horsepower:
<strong>
60 + 2.72966 = 62.72966
708.3096 / 62.72966 = 11.29 or 11.29:1 compression ratio
[ December 06, 2001: Message edited by: horsepower ]</strong><hr></blockquote>
I get 11.03:1 for 60cc combustion chambers.
I have a spreadsheet I have written to calculate this easily. I am working on an article and will release the spread sheet with it. I might release the spread sheet a little earlier.
Eric
Old Dec 6, 2001 | 01:45 PM
horsepower's Avatar
[quote]Originally posted by wizkid:
<strong>
Eric</strong><hr></blockquote>
yes, i fixed it - goofed my first post <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 18, 2002 | 06:27 PM
BADZ's Avatar
Moderator
Is that with a stock 5.7L head milled .030 to achieve 60cc? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by wizkid:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by horsepower:
<strong>
[ December 06, 2001: Message edited by: horsepower ]</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I get 11.03:1 for 60cc combustion chambers.
Eric</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Dec 18, 2002 | 11:06 PM
jhelms's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jhelms:
<strong>WAY BACK IN DECEMBER 2001</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wow, this post came back from the grave! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
