What to Do Next - Big Duration on a 115??
The previous cam was a 224/224 114 which had decent manners (900 rpm idle and no surge at 1200), but I'm trying to stretch a little more power out and use a 900 - 950 rpm idle with no surge at 1300 so I was thinking of a comp XE-R:
228/228 115 +4
or
226/230 115 +4
I'm pretty sure the 228/228 114 has been run sucessfully and probably would meet my drivability criteria. However, I'm somewhat curious to see what a 115 LSA would do, if anything. Could I drop the idle back another 25 - 50 rpm? Does the increasse in LSA defeat the gains from increasing duration?
So what happens when you combine a lot of duration with a high LSA?
<small>[ December 12, 2002, 08:15 PM: Message edited by: Ragtop 99 ]</small>
<strong>So what happens when you combine a lot of duration with a high LSA?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You shift your car really high.
could you try something along the lines of the TR 227/224 114 ( with maybe more lift for your heads )
it should idle well, make good power to 6400, and let u shift no later than 6800 or so....
-Alex
Theoretically, the wider LSA will make the power band start slightly earlier, and it will maintain power slightly longer after peak HP is reached. Peak HP and TQ will be slightly lower. However, with only one degree of difference in LSA, the net effect will be very minimal.
Vice: what rpm or speed is your buddy using for lock-up?
Alex, I think ARE big valve heads like mine respond better to single or traditional split patterns.
You'll pick up some drivability over the cam you have now, and you'll still be able to wind the engine out without it running out of breath. I think it will work out well for you. Besides, now is the time to buy a cam since we're having a cam sale! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Trevor
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I think a 228//228//115 would idle like a B1 but you'd have to advance it for sure to keep the peak from being too high.
Dug: The MMS cam is what made me think that it would work. It runs close to 230 duration on a 114, so my guess is a 228 on a 115 would perform close, but have slightly better drivability.
Those are the correct numbers for the the mms229 cam. I bought one used and those were the numbers on the cam card. I havent installed it yet so I cant tell you anything about the idle quality. Some say its smooth some say its rough. Probably a matter of tuning and idle speed. I have a M6 so it doesnt really matter. If youre interested, MMS has a dyno of that cam on their website. Its in a z06 corvette.
Good Luck!
<small>[ December 13, 2002, 09:19 PM: Message edited by: dug ]</small>
