Head Swap Hints/Advisories
Old May 8, 2007 | 03:16 PM
1BadTA13's Avatar
Default Head Swap Hints/Advisories
I'm doin a head swap on my '00 WS.6, im using the guide on LS1 How-To.com, and it has been pretty good so far, i am down to taking the headers and the power steering pump off, i just took the valve covers off today, does anyone yhave any hints or advisories for the rest of the adventure?
Old May 8, 2007 | 03:37 PM
Viper's Avatar
If you can, use a shopvac to vacuum out the coolant from the heads and block, makes cleanup a lot easier. Make sure you get ALL the coolant out of the bolt holes.
Old May 8, 2007 | 04:58 PM
1BadTA13's Avatar
alright...makes sense...thanks...anyone else?
Old May 8, 2007 | 11:28 PM
CATDIESEL's Avatar
get the right tool to remove and install the crank pulley
Old May 9, 2007 | 06:44 AM
cowboysfan's Avatar
on top of this remove the water pump before the heads and with shopvac remove as much water thru waterpump holes on block, this will minimize water going into pistons/bolt holes when you remove the heads. less to cleanup there.
with wire cutters cut off just enough of the pointy inserts under winshield cowling or you will scrape your hand ugly.
you do not need to remove/disconnect a/c radiator, when ready to remove/install cam have a buddy hold it up away enough to clear cam ..
Old May 9, 2007 | 11:44 AM
BAD2000TA's Avatar
Be careful when removing the intake manifold. The brake booster vacuum line wraps around the oil pressure sending unit. Lots of people pull to hard and crack the top off the sending unit. It's cheap at the dealer if you break it, but try not to!
Old May 9, 2007 | 04:33 PM
GuitsBoy's Avatar
Use the shop vac to vacuum out the coolant from the front of the engine while the heads are still attached. When you finally pull the heads, youll have less coolant in there to spill.
After the heads are off, use a drinking straw and the shop vac to suck up any coolant that went down the bolt holes. Much easier than the twisted paper towel method.
Old May 9, 2007 | 05:38 PM
chuckyt1's Avatar
+1 on the drinking straw and shop vac. Tape that thing to into the shop vac and use it to clean (suck) the coolant out of the holes. You'll be amazed how much you get out this way...
Old May 10, 2007 | 01:09 PM
BAD2000TA's Avatar
Wow! I like this idea. I wish I had thought of it before I did my heads/cam swap. Oh well, always next time!
Old May 10, 2007 | 01:59 PM
1BadTA13's Avatar
thanks alot guys good info...
Old May 10, 2007 | 11:27 PM
00 Freak's Avatar
I've used the q-tips with the long wooden sticks to clean the bolt holes. I don't know about you guys but my tranny dipstick was attached to my heads and I pulled off my heads and out came the tranny fluid. Now I need to service the tranny. I don't remember anything saying about unbolting the dipstick from the heads from that write up. Oh well
Old May 11, 2007 | 01:13 AM
2000RedZ's Avatar
Another thing I did is leave all the head bolts in(just a few threads) when you first lift the head, reduces the amount of coolant that gets in the bolt holes in the first place.
Old May 11, 2007 | 02:09 PM
Black_98Z's Avatar
Great idea 2000redz, that is a new one to me.
Old May 11, 2007 | 02:22 PM
jinxedz's Avatar
Took 1-2 Hours to clean the bolt holes out with shop towels and brake cleaner
Sprayed the crap out of each hole, rolled up a towel into a cylinder, and pushed it into the hole until it hit bottem ... then twist it a few times to clean the threads.
Repeat 5-6 times until no more gunk/crap/stains were appearing on the towels
Old May 11, 2007 | 05:49 PM
Bad Blu Formula's Avatar
That method is now obsolete lol. Shop vac ???! All you need to do after you're done sucking them dry is go through with a shop towel and double check things.
Old May 11, 2007 | 05:51 PM
jinxedz's Avatar
Oh how I wish I had a shop vac ...
Old May 11, 2007 | 06:06 PM
davered00ss's Avatar
Moderator
Use a shop vac on the water pump to pull all the coolant out of the heads & block.
Swap is prety straight forward.
Moderator
Oh yeah, take the grounds off the back of the heads before you unbolt the heads.
Old May 11, 2007 | 06:35 PM
Unlimited's Avatar
and....DO NOT use a regular vac, it's not the same!
Old May 11, 2007 | 09:59 PM
85ta383's Avatar
be careful with the torque wrench! some items are inch/lbs and no ft/lbs.
and just buy arp head bolts.. SO much easier than that torque to yeild crap.
