Torquer V2 vs TR224
Old May 30, 2007 | 09:51 PM
sidewayz28's Avatar
Originally Posted by melchoir
I'd go with the 224 Personally. I have two friends with T2s, one was very disappointed with it (even with a great tune), and the other said himself if he was to do it again he'd go with a smaller cam. Both are M6 drivers if it makes any difference.
maybe u guys dont have a good tuner cause when i was done it drove like stock.. this cam is sick with a decent amount of duration and under .600 lift.
Old May 30, 2007 | 11:04 PM
SSpdDmon's Avatar
Originally Posted by SSTowerman
Your not gonna putt putt around in the neighborhood in 1st barely giving it gas and NOT feel the surge and buck here and there with the lift and duration of that cam on a 112.
Umm...actually, the times I feel any surging are few and far between. You can tune 95% of it out - even on a 112. I very often find my self cruising around the neighborhood in the 1200~1400rpm range. Although I do have 3.73's, they're not much different than the stock 3.42's. The trick is in the timing and airflow tables.
See https://ls1tech.com/forums/showthread.php?p=7152362 for more info...
Old Aug 30, 2007 | 10:53 AM
Tram's Avatar
So, if one was going to switch heads, the TV2 could produce more power than the TR224..
Which one of these cams is better for a street only car?
My car will most likely NEVER hit the track.. I want to be able to keep the power where it would be best used on the streets..
I've got a Vig 2800 - which every says in a 3200.. I may pull it and restall it later..
Anyone?
Old Aug 30, 2007 | 11:33 AM
therobman's Avatar
i just sold my tr224 for a t2 lol
Old Aug 30, 2007 | 12:42 PM
Tram's Avatar
Haha..
Yeh, see..
My mods are Vig 2800, Hooker Lt's, GMMG, lid, ported/polished tb and the freebies..
What made you go with the T2 over the 224? I just love the way the 224's sound.. They sound the best as me..
Old Aug 30, 2007 | 01:00 PM
therobman's Avatar
well i just wanted more power the t2 will make about 15rwhp more over the tr224 and i think all cams from texas-speed sound amazing and sound better over the tr224
Old Aug 30, 2007 | 01:01 PM
Tram's Avatar
But does the T2 give up any torque to the 224?
Old Aug 30, 2007 | 01:05 PM
therobman's Avatar
you might lose some power down low but up top will pull like a mother
Old Aug 30, 2007 | 01:08 PM
Tram's Avatar
Man, this is a tough call..
Old Aug 30, 2007 | 01:21 PM
BlueSLPCamaro's Avatar
Seems like everyone likes the T2!
I was looking into MTI's X1 cam and was pretty dead set on it, but this T2 cam seems to be popping up a lot lately and sounds pretty sweet. I might need to do some more research
Old Aug 30, 2007 | 01:22 PM
melchoir's Avatar
I enjoy my TR224. For MY car, with MY intentions, I believe it was perfect for ME.
Old Aug 30, 2007 | 01:23 PM
  #32
Tram's Avatar
melchoir-
See.. that is what I am trying to find..
I want a KILLER street setup..
I don't give one iota about track times, etc.. I'll never hit the track.. Just not my gig..
Old Aug 30, 2007 | 01:49 PM
  #33
MM98's Avatar
I like the T2 for the great power it makes from 3.5-6.5k.... But my motor doesn't see that rpm everyday, more like idle-5k & for that reason I will be going down to a 224/228 xer cam... If the car wasn't a dd I might keep the T2, but it doesn't have enough ***** down low for me, especially when short shifting around town.
Old Aug 30, 2007 | 01:54 PM
  #34
99blancoSS's Avatar
Originally Posted by BlackSVT03
I know a buddy from a local F-body club who bought the TSP Torquer 2 cam, but decided he wanted to go with a smaller more common cam. I told him I had the TR224 cam and was very happy with it. He asked if I would be interested in a trade.
My question to you guys is would it be worth the bigger cam to pull my cam and put the Torquer in and then give him my cam? Would the power difference be noticeable? Ive already got hardened pushrods and PRC springs. Ive got a new LS2 timing chain from when I did my cam a couple months ago, so it should just be a straight up swap that COULD be done in a day or two's work.
Let me know if this swap would be worth it to you guys.
IT would be worth it for him, the tr224 is the better cam
  #35
Tram's Avatar
I think that may have been the answer I was looking for..
I like my ***** down low..
Old Aug 30, 2007 | 01:58 PM
  #36
melchoir's Avatar
I daily drive mine and love it. You can check my dyno graph for power.
Keep in mind it's with an unlocked stall though.
For a daily driver I don't think I'd want anything else personally.
Old Oct 15, 2007 | 05:19 AM
  #37
FullBoreTA's Avatar
Something is wrong here with your HP numbers. They are really low. The old setup I had with a 3:73 rearend gear, 4000 stall, and a 220/220 Comp cam (stock heads) made 360/370 ... UNLOCKED ... through a 12-bolt. Why do you have such low HP? Was it dyno'd on a Mustang dyno?
Old Oct 16, 2007 | 02:24 AM
  #38
sidewayz28's Avatar
sure thing u like power down low.. my car makes OVER 300 ft lbs at 2500 rpms... 350ftlbs at about 3200.. trust me the T2 can make decent power down low
Old Oct 16, 2007 | 02:47 AM
  #39
mcamarols1's Avatar
i made 407whp and 375tq through a 12bolt w/3.73s, stock pulley, unported TB. its a beast from 3k-6.8k, and now that i have a ported TB and a pulley its even more of a beast
Old Oct 16, 2007 | 03:31 AM
  #40
sidewayz28's Avatar
what kinda heads you using?
