Torquer V2 vs TR224
Old May 30, 2007 | 10:41 AM
BlackSVT03's Avatar
Default Worth switching to a Torquer 2 from TR224?
I know a buddy from a local F-body club who bought the TSP Torquer 2 cam, but decided he wanted to go with a smaller more common cam. I told him I had the TR224 cam and was very happy with it. He asked if I would be interested in a trade.
My question to you guys is would it be worth the bigger cam to pull my cam and put the Torquer in and then give him my cam? Would the power difference be noticeable? Ive already got hardened pushrods and PRC springs. Ive got a new LS2 timing chain from when I did my cam a couple months ago, so it should just be a straight up swap that COULD be done in a day or two's work.
Let me know if this swap would be worth it to you guys.
Old May 30, 2007 | 02:34 PM
Xtnct00WS6's Avatar
I think that would be worth the swap. I might be biased since I'm actually swapping out a TR224 114 for a cam that's similiar to the Torquer 2 cam. If nothing else, I want that extra lopey sound = )
Old May 30, 2007 | 02:36 PM
sidewayz28's Avatar
Torquer 2 is where its at.. you might lose some power down low but be ready for gobs of power from like 3-7k rpms
Old May 30, 2007 | 02:43 PM
BlackSVT03's Avatar
Thats what I was told. Everyone I talk to said that it would feel slow off the line, but once you hit that sweet spot, it just threw you back in your seat.
I might be hurtin a little but I JUST put a 3200 stall in my car and am not motivated to pull it out, sooo Ill be slow till I can get some 3.73s in my car.
Thanks for the input guys
Old May 30, 2007 | 02:46 PM
SSpdDmon's Avatar
Why not just ask him if you can drive it and see for yourself??
Old May 30, 2007 | 02:47 PM
sidewayz28's Avatar
ive got an M6 still on stock gears.. i put heads, 90/90, TDs, new clutch and its super surgy down low w/out a tune, but im not too sure how that cam would do with a 3200 stall + 3.73s.. maybe need a larger stall? duno. but DO THE TRADE!
Old May 30, 2007 | 02:48 PM
SSpdDmon's Avatar
It'd be fine with that setup. Surge is in the tune...
Old May 30, 2007 | 02:49 PM
sidewayz28's Avatar
lol i know, waiting on the nitrous
ELDIABLO's Avatar
With that stall and 3.73 gears your car would be a monster of the line and you'll still have that top end power. IMO Do it!
Old May 30, 2007 | 03:02 PM
transamfreak01's Avatar
yeah do the trade.. that cam w/ the stall and gears will show show nice numbers... that what im going with too but a ss3400
Old May 30, 2007 | 04:27 PM
Midnite_LS1's Avatar
Im in a similar situation and I have seen a couple of dyno #'s on here and there is not much of a difference in power...havent seen any track comparasions. I dyno'd 393/378 and compared it to a car on here with a TQ2 that made 399/377, he had pulley, ported tb and mine were still stock...the only couple of hp were made at the peak, which was a couple hundred rpm's higher than mine...my bottom end did look better though
Old May 30, 2007 | 04:49 PM
GT Griller's Avatar
All dynos will be different from one another so comparing dyno sheets put up here from different places will not really prove much, that and every car will react different aswell. In theory the torquer 2 should be stronger and worth it in my opinion.
Old May 30, 2007 | 05:50 PM
BlackSVT03's Avatar
Wow... ok well it looks like a go. Im doing the cam (brand new in box) and giving my 224 to my friend.
Old May 30, 2007 | 06:24 PM
melchoir's Avatar
I'd go with the 224 Personally. I have two friends with T2s, one was very disappointed with it (even with a great tune), and the other said himself if he was to do it again he'd go with a smaller cam. Both are M6 drivers if it makes any difference.
Old May 30, 2007 | 06:38 PM
GT Griller's Avatar
Like i said every car will act different to different set ups. Ur friends didnt like it, my buddy Kyle put down 415hp at TSP with his torquer2 in his 02 Z28 M6.
Old May 30, 2007 | 06:55 PM
melchoir's Avatar
One of the aforementioned people put down 423rwhp/381rwtq with his T2, but he still said if he was to do it again, he'd likely go smaller. The difference in these cams is *generally* around 15rwhp, but at only at high RPMs.
It's really personal preference.
Old May 30, 2007 | 07:12 PM
teke184's Avatar
"The difference in these cams is *generally* around 15rwhp, but at only at high RPMs."
that's because the heads have become a major restriction once you start getting up to cams the size of the T2.
but upgrade the heads and you'll see the true potential.
put some good ported heads on a T2 and you're likely to see 40hp increase. but put the same heads on a 224 cam and you'll see 25hp.
thats why you see a dozen cams ranging from high 22x up to mid 33x all making 400-420hp, but when you add the heads...some are pushing 460 or 470rwhp.
the heads unlease the power.
the recent trend is to go BIG on the cam...and often people are disappointed. untill they put heads on too
Old May 30, 2007 | 07:28 PM
ELDIABLO's Avatar
As soon as I get a some money im goining with heads for my TV2. Mine made 425hp and 397tq with cam, headers, cut out, and a MTI lid. Im hoping to get 450+ hp with heads!
Old May 30, 2007 | 09:36 PM
SSTowerman's Avatar
Your not gonna putt putt around in the neighborhood in 1st barely giving it gas and NOT feel the surge and buck here and there with the lift and duration of that cam on a 112. I don't care how good the tune is. I know. I've got the cam with stock heads for now.
The cam does take some getting used to. I've got an M6 with stock gears and it is slower off the line than I thought it would be. However, that can be corrected with some gears. It's a beast to say the least from 3k to 6.3k rpm. I haven't been past 6.3k and I wouldn't recommend it. A set of heads like PRC LS6 stage 1s or stage 2.5s and your at 450rwhp easily.
At first, I thought the cam was too big for me around town. Like I said, it takes some getting used to it. I did alot of mods all at once. Cam + full boltons + tune + SFCs. Needless to say I was shocked for a week or so with just the daily street manners of the cam + mods. Would I do it again? HELL YES! Me and the T2 get along just fine around town now. I know what the bitch needs to be in the happy zone. Also, I've yet to realize the full potential of this cam. Gears and a set of heads are next. Would I go to bigger cam? HELL NO! T2 is big enough for my daily driver habbits.
Bottom line is you should be happy if you realize that you'll need to help the cam out with appropriate supporting mods. So you then realize that you'll probably need to spend some more coin. If you don't want to do this then keep the 224.
Old May 30, 2007 | 09:47 PM
sidewayz28's Avatar
i made 395 rwhp through cats, stock 241 heads on a STINGY and i mean STINGY mustang dyno with my T2... id love to see a torquer 2 vs a 224 race
when i was just cam + exhaust, after my tune it was like STOCK no surging at all even with A/C blasting
