Ratteling Sound!!!!!
Old Jun 1, 2007 | 02:18 PM
ls1leadfoot's Avatar
Default Ratteling Sound!!!!!
JUST DROVE AROUND THE BLOCK AND I HAVE A SOUND COMING FROM THE FRONT OF THE MOTOR.....LIKE A LOOSE BALL ROLLING AROUND THE FRONT OF THE ENGINE.....TOOK OFF THE VALVE COVERS AND CHECKED ALL THE ROCKER ARMS....GOOD.....NOTHING IN THE TRANNY......SOUNDS LIKE ALLMOST AS FAR FORWARD AS THE TIMING CHAIN...BUT NO MISS OUT AND SPUTTERING OUT.....RUNS FINE....I ALSO VIEWED THE THREAD ABOUT THE COLLAPSED LS7 LIFTER.....THATS GOT ME WORRIED......MY SERVICE MANAGER SAYS SPUN BEARING.....OTHER GUY SAYS ROD????.....HELP ME OUT...
Old Jun 1, 2007 | 02:43 PM
Default again
there are also metal shavings in the oil......very very tiny pieces
Old Jun 1, 2007 | 03:28 PM
Kryckter's Avatar
How recent is the clutch? Does it do it when its warmed up? Or mostly when its cold?
Some of the newer Ram HD clutches have been making that exact noise you are describing. Some days, mine is pretty bad, others its not. Also depends how hard I have been on the clutch lately.
Old Jun 2, 2007 | 09:56 PM
bigben77's Avatar
guys i have the same problem, i bought this car from a guy on this website and when i start the car you can here something rattle pretty bad in the front of the engine. once it is on you wont hear it anymore. any ideas what it can be. i've been trying to get a hold of the seller but he has not shown any interest in calling or e-mailing back. can someone help me?
Old Jun 3, 2007 | 11:13 AM
bigman1's Avatar
If the noise increases as it warms up it is probably a spun connecting rod bearing, I am currently working on one with the same problem as you are describing, crank the car and unhook the coil packs one at a time, listen for the noise, if it quits then that is the problem cylinder. The metal in the oil is more then likely bearing material.
Old Jun 3, 2007 | 11:31 AM
i have determined it is a spun bearing.....not good....any pointers on new block and rotating assembly with my current set up??? of if anything for sale on forum let me know thanks guys
Old Jun 7, 2007 | 07:03 PM
bigman1 what set up are you going with as we speak???....how much and where are you getting parts from......it sucks starting summer with no ride......too many mustangs around to kill...haha
Old Jun 7, 2007 | 07:26 PM
Tainted's Avatar
dude yuor block is probably fine. just get all new bearings and some nice rods and pistons and be done with it. swap all your old stuff back over
Old Jun 8, 2007 | 11:07 AM
Redneck02's Avatar
i would say spun bearing, had the same sound coming from my buddies z28. turned out it was 3,4 that spun the bearing.
