The "recipe" to 500 rwhp with heads and cam.
#403
Build list
2005 Z51 Corvette with an LS2
Texas Speed 1 7/8 catless headers
Z06 Bimode exhaust
Ported FAST 102mm
Ported Throttle body
Comp cam 230/234 .612/.598 114
I'm adding a set of Tony Mamo 223 Sportsmans heads and Yella Terra Roller Rockers. Also adding some LS7 injectors to support my fueling needs. My previous FAST setup was not ported so I sent it off have it ported.
http://www.corvetteforum.com/forums/...-underway.html
http://www.corvetteforum.com/forums/...ls2-build.html
#404
Yes, I know this thread is like 800 years old and gets a social security check, draws a pension and has an IRA.
However, it's a fantastic read.
Are there some newer 500 whp recipes for LS1/LS6 we can add to the list?
Still seems like this thread would be a sweet sticky!
The following users liked this post:
DualQuadDave (10-15-2023)
#405
Moderator
Received 1,837 Likes
https://ls1tech.com/forums/generatio...-me-first.html
Actually, it is in the stickies. A long time ago, PatG combined a bunch of stickies into a single thread, likely because the sticky section was getting enormous.
The following 4 users liked this post by Darth_V8r:
99 Black Bird T/A (03-08-2022), miami993c297 (03-08-2022), NAVYBLUE210 (03-09-2022), WS6 #3392 (03-08-2022)
#406
And what makes this thread really great is that for the most part, it stays on topic. AMAZING! It’s a great thread for sure.
The following 5 users liked this post by Che70velle:
54inches (03-14-2024), 99 Black Bird T/A (03-08-2022), G Atsma (03-08-2022), NAVYBLUE210 (03-09-2022), Tuskyz28 (03-13-2022)
#407
Compression:
Compression is your friend, especially when running a larger camshaft. Raising static compression will really pump up torque, but so will raising dynamic compression. Every 1 point increase in static compression ratio (SCR) will increase your torque 3-4%. There are limits to how much you can run on pump gas, but you can cheat this limit with tighter quench and better tuning.
For my quest to 500 rwhp, we chose to get static compression into the upper 11s and dynamic compression into the upper 8s. A 57cc chamber coupled with flat top pistons and 2cc valve relief made my compression fairly high for pump gas, but we got some additional help with a .041" head gasket (Fel-Pro 1041). The thin gasket raised our compression from 11.50:1 to 11.92:1 (compared to a stock .053" gasket), but the tighter quench made the motor less prone to detonate at 11.92 than it would at 11.50:1.
The intake valve closing point of 48 degrees ABDC at .050" made my dynamic compression 8.86:1. With the tight quench and outstanding chamber design of the AFR 205 heads, I get 0 knock retard on 93 octane. Ignition timing at peak torque is 28 degrees and 30 degrees at peak hp.
I'm wondering what online calculators you used. I use the Wallace Racing calculators for mine.
Bill Bowling (09-30-2023)
