Un-milled 5.3 truck head = what compression ratio?
If you use 5.3L truck heads, they will need to remove a little material from the chambers (around the valve area) in order to unshroud them.
My TEA 5.3L heads have been milled just .003" and the valves unshrouded. That gave them a 63cc chamber
10.8 to 1 CR using stock graphite head gaskets..... And thats plenty with pump gas IMO
Ron,
Ron,
Ok, there going to be milled .05 thousands. What compression Ratio?
I think you mean .005" (5 thousands)
