Which TSP H/C package would you choose?
Old Aug 3, 2007 | 06:08 PM
deathcharge's Avatar
Default Which TSP H/C package would you choose?
I was set on TSP's LS6 heads and MS4 combo. But I been reading alot of good things regarding the ms3 coupled with the terminator heads. The ms4 won't fit with the terminator heads without flycutting but the ms3 will.
So which of the 2 would you choose and why? Btw, I was also possibly considering the torquer v3 with ther terminator heads
Only thing that sways me with the MS cams is from what I have been reading the lack of power under the curve hense possibly the torquer v3. I realize lower gears would get me in the power band alot quicker so a 4.10 moser would be the next in line project.
Intentions of the car is a every other weekend play car with occasional track time. I would like to crank out 450-500rwhp
98 T/A kooks headers, A4 stalled 3600
Thank ahead of time for your inputs!
Old Aug 3, 2007 | 07:41 PM
joblo1978's Avatar
The magic sticks should get you there, but I would go with the Torquer for more under the curve power.
Magic sticks are too big for my taste.
Old Aug 3, 2007 | 07:47 PM
0utLawZ28's Avatar
slp makes a realy good set up afr heads with a slp cam
Old Aug 3, 2007 | 08:00 PM
camaross383's Avatar
I am in love with the MS4 idle so i am biased...
Old Aug 3, 2007 | 10:17 PM
mudflap1989's Avatar
The MS3 is notorious for being soft down low, but the MS4 does a lot better under the curve than the MS3.
Old Aug 3, 2007 | 11:01 PM
BYE RICE's Avatar
My own personal experience with an MS4/LS6 is a good one.
My friend installed the MS4 into his otherwise stock LS6 long block..It runs GREAT..
It just seems to hit right..4.10's & Jeremy Formato tune make it all work on the street.
Totally streetable as long as your not an old man..& gets 23 mpg highway.
Long tubes required..3" QTP Y-pipe help,too.
Old Aug 4, 2007 | 12:52 AM
TXZ28LS1's Avatar
go MS3!!!! dont worry bout down low!! your verter and gears will take care of that issue!!
Old Aug 4, 2007 | 06:48 AM
GarrettT/A's Avatar
If you go with this setup(termy's+MS3), make sure you order those heads with recessed valves, it wont clear otherwise.
I sure wish TSP would have told me that when I ordered my terminator's
Old Aug 4, 2007 | 08:40 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've got the 5.3/MS3 combo and I'm very pleased with it
Old Aug 4, 2007 | 08:42 AM
MVDCGTO's Avatar
Pardon my ignorance but what are the "terminator" heads from TSP?
EDIT: Never mind I found them.
Old Aug 4, 2007 | 09:19 AM
N4cer's Avatar
Might want to read the results people have had with them first.
Old Aug 4, 2007 | 09:41 AM
PREDATOR-Z's Avatar
You'll not hit anywhere close to 500rwhp on a stalled A4 with those heads.
MS4 can get close but only in high compression form with flycut, TFS/AFR heads and a shitload of detailing hours.
Old Aug 4, 2007 | 11:30 AM
99blancoSS's Avatar
Thats called attention to detail. Something they lack very much. Great prices and they move a lot of product but their attention to detail is very lacking. Having bought from a dedicated head builder I now know what I've been missing.
If TSP would put as much attention into detail and quality control as they do pricing and selling then they would be un-beatable.
Old Aug 4, 2007 | 05:42 PM
I guess I'm asking which of the 2 setups would bring me closer to my 450-500rwhp goal?
From what I've been reading on here, it would be the ms3/terminators setup
Old Aug 4, 2007 | 06:23 PM
99blancoSS's Avatar
Depends on who you ask. It should be a good combo for you but theres no gauranty. For a couple hundred more I'd go a different route. The terms are good with an ls6 intake maybe but I added a 90 and didnt gain anything with it. There is a port mismatch on the intake side that is substantial when matched against a 90.
You've got an A4? You'll need the planets lines up for 450-500. For the money for the terms 1899 with .660 lift springs I'd go afr's and have Tony spec you a cam. Tell him I sent ya... lol
If your deadset on a TSP combo then the ls6 heads stage 2.5 with ms4 would be my choice.
You could also look at Patriot if your trying to save money. They have outstanding customer service and would be my choice for saveing money on heads. Customer service is far far far better
Old Aug 4, 2007 | 06:28 PM
BYE RICE's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
Old Aug 4, 2007 | 09:12 PM
MVDCGTO's Avatar
Torquer V3 ???!!
Old Aug 6, 2007 | 11:11 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Wow I had no idea we had poor attention to detail. We use the BEST cnc valve job system available! I believe AFR is the only company that even offers LS heads that feature a cnc valve job system like our Newen.
Checkout some of the dyno results in the dyno section.
460rwhp heads cam with ls6 stage 1 heads & ls6 intake:
https://ls1tech.com/forums/dynamometer-results-comparisons/760837-tsp-prc-ls6-ms3-460rwhp.html
494rwhp Terminator head combo with the intake that you claim makes no additional power on terminators
https://ls1tech.com/forums/dynamometer-results-comparisons/760089-ryans-performance-texas-speed-494rwhp-na.html
That's just what's currently on the first page, but I think you guys get the idea.
Here's the bottom line:
We pay so much attention to detail that our cylinder heads valve depths are checked to within .0004"! We also build a valve job with virtually no run out! Tell me how many cylinder head shops on ls1tech can tell you that?
Checkout www.newen.com & http://www.newen.com/automotive/pdf/...06-CLAM-GB.pdf
for more information on the valve job that goes into EVERY SET of PRC cylinder heads.
I guess even cylinder head only shops feel they need to bad mouth PRC products in a attemp to gain some market share. Honestly all that does is let me know we're doing the right things!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Aug 6, 2007 | 11:43 AM
Patrick G's Avatar
LS1 Tech Administrator
I recently tuned a Texas Member's car who was running PRC stage 2.5 LS6 heads with 59cc chambers and a cam similar to TSP Torquer V3. It made dynojet numbers in the 460s for rwhp and torque in the 440s. The mid-range torque was phenomenal.
Very good cylinder heads, lots of compression, and well-matched camshaft. Combo, combo.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 6, 2007 | 11:46 AM
Patrick Tony M. to port a fast 90/90 combo for that thing! I'd like to see her hit 490s!
__________________
Jason
2005 Twin Turbo C6
