the most powerfull cam you can put into a ls1
what are some of the best cams for a ls1 .. looking for ones with big hp gains
i dont have much knowledge of the ls1 engine but do you have to have to upgrade other items to upgrade a cam? .. if so can you list those also
thanks
thanks
1 Post
How about the LG Motorsports g5x3 or g5x4 cam. Both would require you to upgrade your valvetrain. Hardened push rods, dual valve springs. Don't forget proper tuning.
LG cams seem to be a winner, MS3/4, TRex, Vengance cams, or all else fails just go custom. Guy here (can't remember name) put a 245/250 in his car, stock cubes. The sticky has great info. For those valvetrain upgrades are an absolute must. Tuning is one of the most important parts IMO. Good luck.
-J
-J
you dont need a cam. Try not to read this and let me come off as a dick, but you got no idea what youre doing. You have to do so much before you can even SUPPORT having a cam. A BIG cam without enough intake/exhaust work will choke it out and really defeat its purpose. Also great flowing heads will help that big cam. You might also have to flycut the pistons if you have to much duration.
You really need to stop. organize a REALISTIC plan. Set yourself a goal, and the amount of cash you want to spend. Dont go on a spending spree with no limit or goals in mind. There are endless possibilities and routes to go down. this site has a amssive database of info for you to research so do that before you start throwing money around.
** There all better, had a stupid mcdonalds eating moment
1 Post
Originally Posted by Tainted
you dont need a cam. Try not to read this and let me come off as a dick, but you got no idea what youre doing. You have to do so much before you can even SUPPORT having a cam. A BIG cam without enough intake/exhaust work will choke it out and really defeat its purpose. Also great flowing heads will help that big cam. You might also have to flycut the ehads if you have to much lift.
I agree with this idea. Do you know what you want other then just a big cam. A big cam is only as good as the supporting mods. Consult with some of the sponsors. They can give you a dose of reality when it comes to dollars and cents. It costs a lot of money for hp, start saving now.
i would have to agree with tainted completely.... heres some tips
1) READ THE STICKIES!!!!!
2) Decide what your budget is going to be for the car
3) Get all of your supporting mods (stall/clutch, gears, headers, tb, intake, exhaust and tires) i would also look into suspension
4) RESEARCH RESEARCH AND RESEARCH!!! if your car is an a4 you will have to match up your converter w/ the cam you choose
5) Research cams!!!! there are plenty of small cams (224 or 228) making 400rwhp and they are hitting ets in the 11's!!!
you will learn that bigger is not always better. just because you might have a huge cam someone else with a smaller cam might walk right over you down the track. be careful with your decision and i cannot urge enough to research EVERYTHING. goodluck
holy ****. Im saving this page, people AGREE with me w0w!!!!
Another peice of advice, what is this car gonig to be doing? Drag racing? Auto X? Choosing a cam and heads to put you in your powerband can help you leaps and bounds. for drag racing, high rpm's start as soon as you launch. Auto X on the other hand, you will be in lower rpms in twisties n such, so match your combo with the cars purpose.
LS1 Tech Administrator
Originally Posted by camaro_best
only cam 98 camaro A4 with TC 3500 2.5 STR with 3.73
22X 23X .5XX 59X 110 lsa
390 RWHP
new time soon
390 RWHP
new time soon
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Patrick G
Next time, if you're trying to be helpful, try replacing those xxx's with some real numbers. If I am willing the expose every part number of what it takes to hit 500 rwhp with heads and cam, the least you can do is give full disclosure of your cam specs. Teaser specs just **** the people off asking for help.
FWIW, you provide lobe numbers with your cam info, right?
lets see .. . .
Dream about BIG BIG CAM
Ask about BIG BIG CAM
ignore the cam and engine building experts
Put in BIG BIG CAM
Wonder why car no longer runs
Cry that its NOT HIS FAULT that he put in the BIG BIG CAM that should have MEGA MEGA HP
Post question on why his BIG BIG CAM car no longer runs.
Reading posts from and listing to the cam and engine builders is kinda important, don't you think?
Put in BIG BIG CAM
Originally Posted by Old SStroker
Maybe his cam guy didn't give him all the numbers, just the performance he wanted, or perhaps filling in the Xs would make it easier to reverse engineer the cam and he'd rather not have that happen.
__________________
