put cam in, now sounds super charged
i have an 02 six speed ta, and i have full bolt ons minus ported throttle body and udp. now this weekend i just put a torquer 2 and patriot 650 dual springs and harden push rods. now here is my prob, im kicking codes. I am getting p0106 and my tcs light goes on and off. i have been reaserching the tuneing forum and this seems to be a common thing after a install, but now my car seems to whine like its supercharged. and at first i thought i had a vac leak because of the map sensor code be thrown. but from what i have always been told vac is strongest at idle, but this prob seems to match the rpms. i have felt all my vac lines and everything is good. now i think the map code and my tcs prob are because of needing tuned but what would make the car whine. but would the whine maybe have anything to do with the whine. Def stumped here any help would be great. thanks
Well i am having the same problems with my TCS, it just goes on and off on its own, and my car has been tuned. I still have no clue on what could be making my TCS act this way, not even the button works when its acting up. The whine sounds like you should check out your power steering fluid, i know if that goes low when you turn the car has a slight whine to it.
-Joel
-Joel
ЯєŧąяĐ Єl¡m¡иąŧøя ™
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
-Joel
-Joel
Which code is that, i don't remember the codes but i remember some of the descriptions.
-Joel
**Yeah i believe i have gotten that code before:
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem **
-Joel
http://www.hptuners.com/forum/showthread.php?p=101510
This is what your issue is with the TCS. Read this from Hptuners site.
no its not the power sterring was my first guess. but topped it off and still whines. and i know the whine from a super charger is loud but this whine my car has isnt a little noise its not untolerable, im just saying because of the map codes i thought i had a vac leak but im sure i dont because it matches the engine speed and doesnt really start till 2,500 rpms. what ever it is the cam started it i was just wondering what it was and if it is bad. at the start of this thread i was clue less, last night i took everything apart and checked all vac lines, and they are fine. and i am still consistenly throwing map/baro ckt and sometimes rdm misfire, and only once tps. but i pretty sure thats all taken care of with a tune. but still no clue what makes it whine of even if i should worry. but its kinda annoying.
Originally Posted by Ping King
Just make sure that nothing else is wrong before you go ahead and have it tuned.
this is the main reason for me being worried, dont want to drive all the way to get tuned to hear, sorry its broke cant help you. and its a comp torquer 2 i ordered from tsp but its does sound around the intake, but when you put your ear to the lid you really cant hear it. But if its not a prob it just the computer being crazy and the whine is something to do with the cam sucking air im good with it. but you know the thought is always in the back of your head saying the worst
Well i went to the link and i think i got confused reading the first paragraph. So basically theres nothing wrong with my TPS sensor, and that its also affecting my TCS?
-Joel
-Joel
Originally Posted by wags98
Did ya put on a new timeing chain?? sometimes they will give ya a wineing noise>>>>>>>
-Joel
-Joel
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Never had a double (or single for that matter) roller chain make any noise.
Gear Drive style timing chains typically make the noise you refer to - and they make both 'quiet' and 'noisy' versions. The noise comes from the way the gears are cut...
Air/vacuum leaks don't normally sound like a blower whine either.
What brand timing chain did you install?
Have you changed your oil pump at the same time?
-Jay-
-Jay-
the sound is all ways there at the same time. and i didnt change my pump or timing chain. but here is the thing its not coming from that area its coming from the back of the engine near the fire wall. and to me it sounds like its on the driver side mostly. and its just a torquer 2 from tsp
