Car stumblind / missfiring and oil in the intake manifold...
Hey guys, the other day my car started stumbling really bad and misfiring. It's making the car undrivable (also due to the t-rex in it lol). I was wondering if it could be due to a bad PCV system... there was a lot of oil on the intake manifold when I took it off to replace the MAP sensor. The car would hold a strong idle (after I found a fat vacuum leak), but you could definately tell it was misfiring more than normal, and it drives like complete ***(One 1/2 mile trip around the block was enough for me.) I'm starting to think that it's the pcv... I'm going to go to a breather setup on Friday, hopefully that will help.
Thanks for any input!
Yeah... there were a few drips of oil where I laid the PCV hose. Guess it's time for a breather setup... Anyone know where I can find a breather that fits onto the driver's side valvecover, in the back where the PCV hose used to connect to?
It's funny, because my intake ports are SUPER clean. (The motor has 500-600 miles on it...) I am just trying to figure out why it's dumping so much that it's causing the engine to misfire so badly.
There are a couple ways for the oil to get in. There is a line from the valve cover directly to the TB. Then there is the pcv system. The car build pressure and it needs to release it. The EPA said no more releasing it to the atmosphere so GM makes the car eat it. That pressure/air has atomized oil in it.
I followed a setup by see5 on here and havent had issue since. Blocked off the valve cover vent to TB and got rid of my pcv system. I have a large diameter hose going from the oil cap to a catch can that is vented. Blocked off all intake vacuum lines as well, now that it is not doing it's job.
The line from valve cover to Tb will put oil on your TB blade and get sucked in. The line from pcv to intake will suck oil directly into the intake.
Doing what I did fixed my oil consumption, which was directly being sucked/pushed into the intake.
I also moddified his design a little and eliminated the vacuum hose to the intake. With the catch can being vented it was introducing un-metered air into the system.
I ran a -12 or 3/4 inch line from the oil cap to a catch can and vented it to atmosphere. He did the same but included a line to intake which creates un-meterd air so I eliminated it.
Got rid of EGR and secondary air system. Capped off driver side valve cover when removing egr. Capped off valley pan tube as well. Only have one vent and thats the big line from the oil cap to vented catch can. The large diameter line should allow for just the pressure to escape and leave the heavier oil behind. SO far I havent had oil in my catch can only condensation.
Cant suck oil if you dont give it a chance.
heres my setup
heres my setup
Could be a mess as well. I didnt want it vented right there. The gases get a chance to cool by the time they get to my can and then are trapped in the can before venting, steaming right there on the valve cover will produce sludge over time just as the old valve cover vents used to do. I had no interest in that mess on my clean engine
1 Post
http://thunderracing.com/catalog/?ac...vid=3&pcid=316
http://www.thunderracing.com/catalog...&sid=776#P5920
