Comp revises the 918's!!!!
#62
+1 for Chris and Comp Cams. I talked to him on Friday afternoon, and I had my new set of revised 918s at my house Monday evening (along with a set of new Magnum 7.400" pushrods that I ordered with free shipping
). Couldn't have asked for any better service than that. Here is a comparison of the original Comp 918s and the revised 918s (on the right). They both install at 1.800". Once I get my Nova off to the paint shop it will be time to install the new cam in the C5.
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![](http://i178.photobucket.com/albums/w258/cacinal/car%20parts/DSC_5974.jpg)
#64
Yes they are. I didn't mic them last night, but you can visably see that they are shorter. Notice that the seat load is 5 lbs lighter at the same installed height even though the spring rate is higher on the new springs. Also the "open" load is listed .050" more than the old springs, which backs up the earlier comment that these should be OK for .650" lift. I will be using them with .585" lift, so there is plenty of safety factor there.
#66
I dont think they need to be shimmed but I do see that they seem to be good to .650 but thats with only a .050 saftey margin....I still say .625 is where I'd max them out to be safe but thats only an opinion...
#67
#68
so w/o any shims they install at 1.8?
so then you subtract your lift and coil bind. .595 lift and 1.1 coil bind
that gives .105 subtract .05 and end up needing a .055 shim right?
#69
I don't think so. It doesn't make sense that they would redesign springs that are for a specific application and make it so you have to shim them. If that was the case then they would include shims with the springs.
#71
#72
so if i get the 918 with ti retainers (i guess i use my stock locks?) or if i get teh pp or prc gold spring kit. i install the valve seal, then the seat, then spring, then hat, compress then add locks and done?
#74
I would say I've installed 10 sets of older 918's and they all were 1.78 to 1.80 dropping them right on the head...
Never had one problem with them on any of these car,it would be nice to get an swer from Comp on this subject or someone who has installed the new springs?
#77
Edit- So yay or nay on shims? I really just want to remove my old ones and install my new ones, nice and fast.
