headgasket ?
Old Nov 3, 2007 | 08:16 AM
oange ss's Avatar
Default headgasket ?
i have to run 6.0 headgaskets when usin 6.0 heads on an LS1 right ?
Old Nov 3, 2007 | 10:32 AM
99blancoSS's Avatar
gasket should match the bore in the block I believe. Slightly bigger will reduce compression ever so slightly smaller cant be good.
Old Nov 3, 2007 | 11:48 AM
oange ss's Avatar
thanx, that's what i thought..
Old Nov 3, 2007 | 12:13 PM
chriswtx's Avatar
no, use the 6.0l gaskets. the gasket needs to match the bore of the head to seal correctly...
Old Nov 3, 2007 | 12:15 PM
99blancoSS's Avatar
Your right I had it backwards. Thought about it for a few minutes and realized.
Old Nov 4, 2007 | 10:02 AM
Zitty'sZ's Avatar
Are you guys positively sure on this, because I installed Patriots LS6 " style " heads on my LS1 and when I ordered the head gaskets from Texas Speed, I told Jason what I have and he said the 5.7 gaskets would be ok . I don't seem to be loosing any coolant but I have not ran the engine hard yet because I haven't got it tuned yet . I am going to pissed if I have to pull the heads because of this .
Old Nov 4, 2007 | 11:23 AM
chriswtx's Avatar
whats the casting number on the head??
Old Nov 4, 2007 | 02:09 PM
PREDATOR-Z's Avatar
Whether it is the head or the motor you should gasket the bigger bore. So if the head is bigger bore, you gasket that and if block is bigger bore you gasket that.
Although the heads are 6.0, that doesn't mean that they are 4.0 bore (like old PP heads)/
Basicaly always gasket at least .030 over the biggest bore you have.
Old Nov 4, 2007 | 05:55 PM
Zitty'sZ's Avatar
Predator-Z, I was hoping you would respond. Do you think I will be ok with the 5.7 gaskets or do I have to pull the heads and use the 6.0 gaskets ? Chriswtx these are the 035 castings that patriot welded up and then cnc'd them .
Old Nov 4, 2007 | 11:18 PM
PREDATOR-Z's Avatar
Those could be 3.905 bores, in any case it will work NA. But if you ever have to pull the heads, better go with the bigger bore way.
See if your heads are 4.0, then you gasket is showing in the combustion area and that can lead to hotspots (detonnation) or could just blow.
Old Nov 5, 2007 | 08:03 PM
Zitty'sZ's Avatar
Predator-z, my heads are the 3.905 bore chambers so I think it will be ok but I agree with you, if I have to pull the heads for any reason , i'll use the 6.0 gaskets.
Old Nov 5, 2007 | 08:19 PM
chromeplated500's Avatar
wow... i was sweatin the start of this thread... i have a 6.0l block with 5.7 heads.... and i went with the 6.0 gaskets. physically holdingit there and everything it was the only way it would work...
Old Nov 5, 2007 | 10:59 PM
LS1C5Vette's Avatar
Not to jack but I bought 2005 corvette heads (LS2) but they are 243 casting heads so which head gaskets should I be using??
Old Nov 6, 2007 | 01:48 AM
PREDATOR-Z's Avatar
On a 346/347, you should use 5.7L gasket, either MLS or graphite (few poeple still use these).
