Help, possible bad GM LS7 lifter?
PRC 5.3L Stage 2.5 heads
GM LS1 Headgaskets
GM LS7 Lifters
ARP Head bolts
P&P Throttlebody
ASP Underdrive pulley
RAM Powergrip HD Clutch
RAM Adjustable Master
Hypertech 160 Tstat
Anyway... have maybe 60 miles on the vehicle since the install. I started on my trip up to TSP last thursday to get a retune. About 20 miles out I had to turn around because of a tapping noise coming from the engine. It would fade in and out and also change speed with RPM...
Called TSP and John was pretty sure it wasn't a lifter because they don't have issues with these lifters... anyway he had me check the rocker arms and make sure none of them were loose and they werent. He had me check the preload and they checked just fine. Last thing they had me do was change the oil to 20w50, I did. Noise is still there =/
Any other ideas or how I can figure out if it is the lifter?? Or maybe even what side is the issue?
I have been running my LS7 lifters since my H/C swap a few months ago. Haven't had a single issue from any part of the install. I soaked my lifters overnight.
