color code for valve springs/ls1 vs ls6
Old Feb 2, 2003 | 03:12 PM
thedave8's Avatar
Default color code for valve springs/ls1 vs ls6
when i scored my ls6 it was partial dis assembled.
springs and valves removed from heads....i want to make sure they belong to the heads. I noticed the springs are painted, and heard that they were so they went into the correct engine...any info? How do i make sure they are the ls6 valves? I heard they have diff lengths. True? since the cam is missing i want to make sure they didn,t swap valvetrane parts also....T.I.A.
Old Feb 2, 2003 | 03:22 PM
thedave8's Avatar
Default Re: color code for valve springs/ls1 vs ls6
sorry bout the double wammy
thedave8's Avatar
sorry bout the double wammy <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 2, 2003 | 03:38 PM
BigTex's Avatar
LS6 valve springs form 01 should be blue in color and from 02 should be wither solid yellow or have s yellow paint stripe on them. The LS6 springs will have an oval wire compared to the standard round wire from the LS1 spring.
Old Feb 2, 2003 | 04:22 PM
thedave8's Avatar
looks oval, color looks more green than yellow
Old Feb 2, 2003 | 07:37 PM
driftwood's Avatar
The valves have painted dots on their face,of course that may be hard to spot if carbon built up.
Is there a difference between the 01 and 02 LS6 springs,other than the color?What lift are they good for?
Old Feb 2, 2003 | 11:28 PM
Y2K2LS1's Avatar
I have a pair of ls6 springs staring me in the face, they have a light coating of yellow paint on them. It definitely cannot be mistaken for another color, they are yellow!
Old Feb 3, 2003 | 05:33 AM
BigTex's Avatar
The 01 springs are made for stock valves and .525 lift. The 02s are made for .550 lift using the lighter sodium filled LS6 valves of 2002.
