Heads + MS3 vs Heads + TRak
Options:
1) PRC Stage 2.5 5.3L Heads, unmilled with felpro .041" gaskets and MS3 Cam (237/242 .603/.609 112LSA)
2) PRC Stage 2.5 LS6 Heads, unmilled with felpro .041" gaskets and TRak cam (231/235 .640/.590 112LSA)
Thanks Guys!
they recess the valves so you dont need to flycut and everything works great... i dont see why people would buy tsp heads and then go and try and match them up to a different vendors cam...
i figure that if i trust tsp enough to make my heads then i should trust them on the cam too
if i had to do it again id prolly pick my same setup or mabye try and and use the ms4 and eddlebrock heads (providing ptv would work)
If I plan to do another H/C setup I'll go with MS4 and PRC Stg 1 LS6 Heads and if you can flycut the pistons then go with PRC Stg 2.5 LS6 Heads this setup will get 480rwhp+ with Fast Intake.
I vote ms3/heads...
The Only Thing I Can Think Of That May Be Better Is Terminator Heads And Thta Is If You Dont Have To Fly Cut--- Fly Cut Isnt So Great If You Plan On Spraying
