dot to dot cam marks is 2 deg off ?
Old Nov 12, 2007 | 05:01 AM
jeejee's Avatar
Default dot to dot cam marks is 2 deg off ?
i installed a lingenfelter gt2-3 cam using the dot to dot method as there was no adjustable quick single chain sprocket i could get my hands on
but using the ls2 chain which has some more slack that the original chain i measured a 2-3 degree diff.
eg. cam should open inlet at 9 deg before TDC and it opend at 6-7 deg before TDC
no biggie ?
Old Nov 12, 2007 | 06:35 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Seems like with most LS1 cams, advance gets ground in the profile, I bet if you call you will find it what ever the LSA is and then +2.
I never seen such a thing until I got into LS1 motors. Maybe LT1's had it too, I just maybe never noticed lol.
Old Nov 12, 2007 | 07:55 AM
NOBR8KSS's Avatar
I used the Comp Cams adjustable timing chain with my cam install...dot-to-dot, mine was off 4 degrees.
2 degrees can have a noticable effect on torque output...I would get an adjustable timing chain and get it right.
JC
Old Nov 12, 2007 | 01:05 PM
88blackgt's Avatar
+1 on the adjustable
get it right the first time, it makes a big difference.
Old Nov 14, 2007 | 06:14 PM
itslow's Avatar
I recently checked the cam I've installed in my 6.0L - heads off, on stand - and the ICL came out to be right where I spec'd the cam to be ground (111+0). Installed "dot-to-dot" with the stock LQ4 sprockets and a new LS2 chain.
Old Nov 14, 2007 | 06:28 PM
ZO6 Bryan's Avatar
Actually what you should be checking is intake centerline. Not when the valve opens. Find where intake is open .050" then find where intake is .050" from closing. Then split the readings and that is the centerline.
Check this out http://www.compcams.com/technical/Ca...07/379-380.pdf
Old Nov 14, 2007 | 07:31 PM
mrr23's Avatar
did a little dyno testing with my cam today. originally put it in straight up. cam peaked a little soon. so, i retarded the cam 5* to make it 0*. (cam has 5* advance ground into it).
not a good thing to do. this just goes to show that you need to make sure it's installed correctly, or you can lose alot.
Old Nov 14, 2007 | 09:53 PM
hammertime's Avatar
no biggie ?
This is the reason why its always suggested to degree the cam when it is installed. Even though you are using OEM components, there are enough variables that it's not worth taking the chance.
I suppose to answer your question, using the results mrr23 posted, is the possibility of 10 extra HP and 20 lb-ft no biggie?
Many cam manufacturers grind advance into the cam. Its their way of trying to save you from yourself. Too many people follow their finger to the bottom of the page when making cam selections. 4 degrees of advance helps salvage some low-end from a too-big selection.
Also, based on the original posters observation, it should open at 9* BTDC and it actually opens at 6-7* BTDC, that would be 2-3* retarded, not advanced.
Old Nov 15, 2007 | 05:29 AM
jeejee's Avatar
i know i never said it was advanced... but "retarded cam" sounded not quite right
Old Nov 15, 2007 | 01:32 PM
hammertime's Avatar
You know, you're right. We really can't say your camshaft is retarded; it just wouldn't be politically correct.
I guess we’re relegated to “Angularly Challenged” or “Involuntarily Tardy”.
