Help me pick a cam & make a parts list
Old 12-04-2007, 08:08 PM
  #181
sidewayz28's Avatar
yeah... id think the ls7 wouldnt really enjoy the nitrous. youll be making some good power on the spray
Old 12-04-2007, 08:55 PM
  #182
BayAreaSS's Avatar
So what us your overall review for the HD?
How do you rate it from 1-10? (10 being Very good)
Old 12-04-2007, 10:16 PM
  #183
rocksws6's Avatar
A 2. Just because it doesn't slip. It does hold the power. But that's the only thing its good at.
Old 12-05-2007, 12:03 AM
  #184
sidewayz28's Avatar
why do you rate it a 2? because it chatters? im using a RAM adj. master cylinder, new slave cylinder, RAM billet steel Flywheel and the Powergrip HD. its COMPLETELY different then stock. but as far as im concerned its held up great. when u try to get the car rolling you do get occasional chatter, but if you give it some RPM and do it just right it goes smoothly. im making the power in my sig N/A + a 100shot and the clutch grabs HARD every shift
i would give it a solid 7 (assuming id rate a twin disk a 10 and a stocker like a 3)
Old 12-05-2007, 09:25 AM
  #185
BayAreaSS's Avatar
Ok thanks. I know clutches are a hit or miss thing and everyone has different experiences.
Old 12-05-2007, 11:54 AM
  #186
rocksws6's Avatar
Man mine chatters so bad it will chatter when going through the gears. I'm running the exact same setup as you, maybe I just got a bad one. I made sure to clean everything so I know there's no finger prints or anything. I don't know but it sucks. It does hold the power though. Maybe I'm being to critical but I definately wouldn't buy it again.
Oh BTW I got my cam it ended up being a 231.5/233.5 on a 111+2 instead of 230/232 110+2. I guess they have a little tollerance but its close enough to where I don't think its going to make a difference. But its going in Friday and I will be on the dyno Monday. I will try and get some sound clips and a dyno run for you guys.
Old 12-05-2007, 11:56 AM
  #187
blackmaro99's Avatar
Oh BTW I got my cam it ended up being a 231.5/233.5 on a 111+2 instead of 230/232 110+2. But its going in Friday and I will be on the dyno Monday. I will try and get some sound clips and a dyno run for you guys.
Nice!
Mine's going in and getting dynoed next Wednesday.
Old 12-05-2007, 03:16 PM
  #188
sidewayz28's Avatar
thats no good man! i wuold be pissed too if mine did that every gear. i chose RAM because of all the horror stories with the Spec.. then theres all the highend clutches i couldnt afford
Old 12-05-2007, 05:29 PM
  #189
bad6as's Avatar
what about centerforce?
Old 12-05-2007, 05:30 PM
  #190
bad6as's Avatar
the DFX
Old 12-05-2007, 06:20 PM
  #191
BayAreaSS's Avatar
How do you know what the actual size is of your cam?
I cant wait to here the sound clips and see what you put down
Old 12-05-2007, 06:21 PM
  #192
BayAreaSS's Avatar
Thats my same situation. I can't afford the high end stuff so i need something thats affordable but can still hold the power
Old 12-05-2007, 06:26 PM
  #193
lastcall190's Avatar
Thunder put mine on a cam doctor and sent me the card when I got the cam. It was barely off from what Pat spec'd, but it was nice to see.
-J
Old 12-05-2007, 06:32 PM
  #194
sidewayz28's Avatar
i drove a centerforce in my brothers 93 cobra and it was alright, i just went for something different
Old 12-05-2007, 06:37 PM
  #195
BayAreaSS's Avatar
-J
oh yeah i seen something about that on their site. That means i'll get the specs as well.
Thanks
Old 12-05-2007, 09:23 PM
  #196
-J
Mine turned out to be 231.28/232.88 111.94+2 instead of 230/232 111+2
Old 12-05-2007, 11:28 PM
  #197
BayAreaSS's Avatar
I would think if the cam specs aren't right they would grind a new one and make it right. Does anyone know why that isn't done?
is it impossible to get the specs right?
Old 12-06-2007, 06:51 AM
  #198
I'd imagine that's such an infinitesimally small difference that in the long run it really wouldn't make much of a difference. Then again I could be wrong...
-J
Old 12-06-2007, 09:16 AM
  #199
BayAreaSS's Avatar
Im sure it doesn't really matter but i was just wondering
Old 12-06-2007, 12:37 PM
  #200
If you are real curious I would just ask Pat G or Predator, they could probably give you a real answer on whether or not it's possible to get the specs exact.
-J
