Most aggressive sounding, under the curve cam?
If anyone has sound clips along with their dyno graph (or someone else who has that same cam) please share. Thanks, Sam
I did not like how the car seemed to respond to the 3600 stall...would it be necessary or worth it to upgrade my stall if i dont go to the track much?
Also, how does it feel driving around town, and pull throughout the entire RPM range? Thanks
For stock heads I also have been impressed by the flat-TQ curve of the ASA cam.
If you bump up your CR, a number of us have done well with the 228/232 110 custom cam. With 10 degrees of overlap, it has plenty of "aggressive sound", and a nice balance of HP/TQ from 2500-6250 rpm.
I'll try to re-link my dyno graph up. While this is a great street cam, it does seem to respond to higher CR.
Good luck..WeathermanShawn.
not to be a nag but please, if you make a cam recommendation, i would like to see a dyno graph or sound clip of some sort
one last thing for now...would any mods friendly to the wallet be worthwhile to do to stock heads
