Installing REV springs...
Old Jun 26, 2003 | 07:40 PM
JxxxOxxxE's Avatar
Default Installing REV springs...
When I go to install my REV double springs with the new spring seats, will the seat just be able to basically fall in, or do I have to remove the valve seals or anything like that...?
Old Jun 26, 2003 | 07:41 PM
xaon's Avatar
Default Re: Installing REV springs...
you'll have to remove the valve seals and replace them. Other than that, the seats just fall in.
Old Jun 26, 2003 | 08:14 PM
JxxxOxxxE's Avatar
so whats the best way to get the valve to stay up then...?
Old Jun 26, 2003 | 10:35 PM
StevieZ's Avatar
Set the piston at TDC and the valve will have no place to go.
Old Jun 26, 2003 | 10:47 PM
JxxxOxxxE's Avatar
ok, thats what I was thinking...whats the easiest way to figure TDC for each cylinder....?
Old Jun 27, 2003 | 08:08 AM
robertbartsch's Avatar
..hope you are doing this with heads off....PITA
Old Jun 27, 2003 | 10:43 AM
xaon's Avatar
I used the MORE Performance spring compressor and it was easy as pie to put these springs on my heads in the car.
I used an air-valve to pressurize each cylinder and hold the valve up while I changed them out. This is the easiest method if you've got an air compressor.
Old Jun 27, 2003 | 10:58 AM
...these are really stout springs ...i love mine!
Old Jun 27, 2003 | 11:09 AM
Cal's Avatar
Cal
Turn the engine over until the exhaust valve opens then closes; keep turning and the intake opens then closes . . . now both valves should be closed all the way, so turn the crank another 100 degrees and you should be close to TDC.
Another way you could do it is to turn the crank until you find the point where both valves are barely closed, but if you turn the crank either direction from there one valve or the other immediatly starts to open. Then turn the crank exactly one full turn (360 degrees) from there and you are at TDC.
Old Jun 28, 2003 | 02:02 AM
JxxxOxxxE's Avatar
I'll be doing this with the heads on the car...thats why I dont think I can use the air compressor trick to hold the valves up when I pull the valve seals...
So TDC shouldn't be that hard to hit huh...? I hope not...
Old Jun 28, 2003 | 02:23 AM
JoSeY's Avatar
Werd....I love mine w/the MTI X1 cam...not a lot of valvetrain noise and very stout!!
Old Jun 28, 2003 | 03:21 PM
DONAIMIAN's Avatar
The only way you can do it with an air compressor is with the heads on the car
