Flycutting Tools
Old Jun 19, 2008 | 08:43 PM
  #61
Fratsit's Avatar
Originally Posted by LS1C5Vette
I know I will need to flycut thats why I asked that, what exact tool is needed to measure? Can I just use clay and turn the motor over by hand and measure the dents?
Yeah... you can measure that way. That is how I did it with no problems. Make sure you use organic modeling clay and not Playdoh. 1/4 inch strips are fine. I bought mine at Walmart.
Put a little oil on the piston face and valves so the clay wont stick.
I cut the clay in the middle and used a micrometer to measure the thickness.
Nice to see this thread is still helping people out.
R/
Frat
Old Jun 19, 2008 | 10:50 PM
  #62
2001CamaroGuy's Avatar
WOW! I want a set!
Old Jun 30, 2008 | 11:25 PM
  #63
oh5gto's Avatar
I am kinda pushed for time, so I need to know whether I would need to flycut, so that I can get the cutters before I start.
It is stock LS2 with stock heads, head gaskets and valves. Cam specs:
239/254 605/612 114 LSA COMP
7.4 pushrods.
Thanx in advance
Rian
Old Jul 1, 2008 | 06:46 PM
  #64
Irocss85's Avatar
ok then I'll say yes. cut and never think about it again.
Old Nov 28, 2008 | 08:49 AM
  #65
405HP_Z06's Avatar
TTT for those looking at flycutting tools.
Old Nov 28, 2008 | 04:21 PM
  #66
johnster's Avatar
i need a set but dont wont to spent $225, 4 something im going to ues once!!!!! can i rent a set from somebody ill ship them back
Old Dec 14, 2008 | 06:09 PM
  #67
NVR_ENUF's Avatar
Back from the dead! This thread JUST won't die, will it?
I just wanted to add that when you use the 'clay method' of checking PTV clearance, you need to have a SOLID lifter. I built 2 of them using parts from a few others, but you will not get a true reading if you just use regular old stock type lifters.
Old Dec 14, 2008 | 08:22 PM
  #68
405HP_Z06's Avatar
And it shouldn't either, the best flycutting tools around!
Agree on the lifters, this is exactly what I did; great use for old lifters!
Old Dec 14, 2008 | 09:10 PM
  #69
Irocss85's Avatar
yeah, I bought a set of old stockers from someone and dissasembled them, cleaned them, filled them with epoxy and reassembled before it setup. now there perfect solid test lifters.
got some extra's if anyone needs some for cheap. $20 set plus shipping. same ones for LT1 eng.s too.
Old Dec 15, 2008 | 12:42 AM
  #70
studderin's Avatar
I made my only cutters with stock valves, welding a bead around them and turing them back sqare to the size needed. Works ok, they don't center cut,good, and clogged up. So have to switch to a stock valve with 60-80grit to center cut the notch. But for cutting fluts and the cuting face and backcuts, free hand with a cutof wheel I can;t complain.
Old Feb 2, 2009 | 10:26 PM
  #71
JFM-jr's Avatar
Here are some more pics of cutting done with the Lindy tool. I used the same tool Aaron started this thread on. The guy Dave there is great and the cutter's quality and precision is excellent. I am very pleased with the results. I may take a sanding disc and very lightly smooth the chatter markings off the face of the cut because I am picky LOL. The radius built into the tool leaves a nice smooth transition on the inside edge as you can see. These were .060 deep. I'd like to thank Aaron for recommending this company. The only catch I came across was when setting the depth with the collar was you need to pay special attention to the tools orietation on the piston surface. You must be sure the cutting flute is only portion of the tool contacting the piston when setting the depth collar. It is possible for the tool to sit on the piston "between" the flutes and this brings the tool closer to the piston. This would result in a deeper cut than desired so I marked the tools stem to make orientating it easier.
Old Feb 2, 2009 | 11:48 PM
  #72
405HP_Z06's Avatar
They look great, John. The wavy looking chatter marks look much worse in the picture than they really are.
You are correct about indexing a flute on the piston top because, as you state, it can sit between flutes. I did the same and put a mark on the top of the cutter stem to mark flute direction. Thanks for mentioning this.
Old Apr 10, 2009 | 12:14 PM
  #73
ZMONSTER!'s Avatar
What size cutters would be needed for 2.02 and 1.57 valves? I assume you would want to oversize the cutters a small amount?
Oh and by the way Im looking to buy or borrow a set of these if anyone is game.
Old Apr 10, 2009 | 03:30 PM
  #74
JFM-jr's Avatar
You give Dave the valve size he automatically adds enough radial clearance to the cutter for you.
Old Apr 25, 2009 | 02:45 PM
  #75
1SLwLS1's Avatar
This is a neat tool. I may have to do this myself versus paying a machine shop to do it. I wonder how much a machine shop would charge?
Why do you need to use a solid lifter when testing PTV using the clay method? Is it because the stock lifters will compress down or something giving a false clearance or what? I dont know too much about pushrod LSx's
JFM-jr your pistons are winking at me, I dont know how to accept that...
Old Apr 25, 2009 | 02:59 PM
  #76
Thimble's Avatar
That's exactly the reason.
Old Apr 25, 2009 | 03:23 PM
  #77
1SLwLS1's Avatar
I guess thats why they are called hydraulic and not solid
Old Jun 29, 2009 | 05:35 PM
  #78
danhr's Avatar
hate to resurrect an old thread, but is there some contact information on where to buy these?
Old Jun 29, 2009 | 09:00 PM
  #79
405HP_Z06's Avatar
https://ls1tech.com/forums/9284106-post46.html
Old Dec 29, 2009 | 03:04 PM
  #80
chrs1313's Avatar
back from the dead again i am most likely going to use these... thanks for the post
