GM Goodwrench Replacement Engines, $3,551 w/ 100K-Mile Warranty?
On SDPC's Web page (http://www.sdparts.com/catalog/crate...teEngines.aspx), it says:
So, i don't know what the difference is or why they cost different amounts, but the "Pontiac F" looked like a steal, so I clicked on it.
It seems to me it's $3,551.11 for a complete, assembled long block, maybe minus the intake and coils, but with a 100K-mile limited warranty. That sounds like a pretty damn good deal if you have a 113K-Mile '99 Z28 like I do... Wonder if it has the 243 heads?
Am I missing something? Probably am.
Originally Posted by SDPC
12455109GM Goodwrench Replacement Engines 1997-98 Chevrolet Corvette (LS1)(5.7G)$3,551.11
12457660GM Goodwrench Replacement Engines 1999 Chevrolet Y (Corvette) (LS1)$5,754.69
88893287GM Goodwrench Replacement Engines 1999-00 Chevrolet, Pontiac F (LS1)(5.7G)$3,551.11
88893286GM Goodwrench Replacement Engines 2000 Chevrolet Corvette (LS1)(5.7G) MFI Alum$4,551.54
Every Goodwrench engine is made to the same engineering standards
that go into every new GM vehicle. They’re tested to perform under
the most demanding conditions, assuring you the reliability and
quality you expect from the Goodwrench name and they’re backed by a
36-month/100,000 mile transferable limited warranty.
New GM Goodwrench engines include:
cylinder block
head and valve train assembly
camshaft
lifters
oil pump
piston assemblies (connecting rods, pins and rings)
timing components
bearings
seals
all tin ware
cylinder block
camshaft
lifters
oil pump
timing components
bearings
seals
all tin ware
LS1TECH & Trucks Sponsor
You're not missing anything. GM Goodwrench engines have the best warranty in the business! That warranty is also good at ANY, and yes I mean any, GM dealer in the nation! If you have a simple problem, take it to your dealer and they fix or replace what's wrong. Now some people complain that they don't trust their dealer....in some areas that's understandable and the service manager at the dealer can in some cases approve the warranty/labor to be done by an independent service facility!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
The LS4 did have the same castings as the LS6/LS2 however, so you weren't completely wrong.
__________________
^Good question.
Also, if it doesn't come with the 243's then what heads does it come with?
And, what all doesn't come with this engine? There's so much I don't need, like coils, intake, manifolds...
My daily driver, my only car, is in the garage. Knock-knock-knock-knock!![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Can't figure out a way to configure another engine for as much or less using your budget 346 shortblock ($2,789) even with Patriot's super Christmas heads/cam sale prices: CNC ported 243 castings with oem (non-sodium valves), Patriot Gold Dual springs, Patriot 225/229 .580"/.590" 114 lsa cam, oem head bolts, and hardened pushrods all for $1,395.That's $4,184 without oil pump (which I need) or timing chain...
SDPC,
Is this for one or a pair of LS6 (243) heads, and if so, would they bolt right up to your budget short block, and if so, what would be the cost of hainvg you do so?
If you get my drift, I'm trying to upgrade my LS1 and get a new one at the same time for the least amount of money possible.
Budget shortblock: $2,789.
SDPC Blueprinted Oil Pump: $150.
LS6 2002-2003 Cylinder Head Assembly: $750.
2002 and Newer LS1 / LS6 Head Gasket Kit: $26.
Head Bolt Kit, LS1 1997-2003, Kit for One Head (x2): $36
Sub total: $3,751
Labor: $???
Custom-grind Comp cam kit with hardened pushrods: $???
Labor for that installed: $???
Shipping to 62439: $???
Like I say, my only car/daily driver is down right now, so I'm no window shopper.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Sub total: $3,751
Labor: $???
Those are individual heads. But for a budget head, you could go with the LS2 heads instead and still get the great flow of the LS6....just with a slightly heavier valve in the head. They are a good bit less expensive too!
__________________
Sorry, they got removed from that page somehow. I added them back and updated the LS2 head's info!
__________________
For the LS2 heads you offer, are they shipped ready to be bolted on and go (minus the gaskets), or are there other parts needed before bolting them on (valves, springs, rods, etc.)?
Also, for the LS6 hollow stem valves, is that one package for BOTH heads, ALL valves? With that upgrade, are the LS2's basically LS6's at that point?
I'm asking because 1) the awesome steal of a deal on the LS2's and 2) I have a .562 lift cam in my car now (the LS6's state that they can only take a cam lift of .550 and less, so I'm guessing I can't go that route without having to get a new cam...)
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
^Good question.
Can't figure out a way to configure another engine for as much or less using your budget 346 short block ($2,789) even with Patriot's super Christmas heads/cam sale prices: CNC ported 243 castings with oem (non-sodium valves), Patriot Gold Dual springs, Patriot 225/229 .580"/.590" 114 lsa cam, OEM head bolts, and hardened pushrods all for $1,395.That's $4,184 without oil pump (which I need) or timing chain...
Just responded to a fire in my company's 4-door cavalier... The guys gave me sooo much **** 'cuase they know I'm hating not haveing my Camaro! ![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Alan, thanks for the reply. Will be calling you.
Otherwise, for anyone who's following this, The above LS6 prices didn't include rocker arms (head prices never do, duh) and were for only one head. The assembled LS2 heads are $600 a pair and are part number 12576063. That changes the cost of my unofficial SDPC budget build to:
LS2 Cylinder Head Assembly: $600
Rocker Arms and bolts: $???
Custom grind Comp cam: $???
Pushrods: $???
Gah, if I were smart, I'd just get the Goodwrench replacement for $3,551... That's just no fun.
Pushrods: $???
I hope it's ok to post this, but it's better for my records since I'm at work, and I think everything is list price...
But, here's my quote from Marty:
346 LS6 Economy block assembly.............$2789.00
LS2 head assembly........................2@....$299.95
Head Gasket kit............................Pr......$25.95
Cam and Head install kit.........................$279.95
Remaining gaskets and seals...................$42.31
Rocker Arms...............................16@....$10.49
High Pressure oil pump...........................$88.94
SD double row timing set........................$114.00
Lifters........................................... ......$99.95
Pushrods.......................................... ...$88.00 set
Total of parts........................................$4295 .84
Labor to install heads.............................$65.00
Freight charges.....................................$165.0 0
Total Charges.......................................$4,5 25.84
Thanks, SDPC!
Thanks, SDPC!
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
I have a question for SPDC on this motor just because I'm a curious cat
Do these engines come with the "LS6" block with bay to bay breathing windows and improved oiling, or are they built with the 98-00 LS1 blocks? Thanks,
Larry
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Larry
