guys with 408strokers or anyone opinions needed on set up
im getting ready to do a 408 stroker on my silverado ...and probably leaning toward the texas speed stroker block but my question is how does this build sound with a vindicator cam or a texas giant cam would this be a killer 408
i believe this set up is gonna brin the compression up to about11.6:1
wat numbers should i see
408 cid short-block
diamond -2cc pistons
callies compstar 6.125ls1 rods
callies compstar crankshaft
total seal plasma moly/napier 2nd ring set
with slps
Cylinder Head and Manifold Package, SLP/L92 Drive by Wire (64cc)
SLP's L92 cylinder heads are surfaced milled and come with a CNC'd finished chamber. The combustion chambers are set at 64cc's (stock 70.2cc) and come with Competition Cams 918 valve springs (SLP# 53003) which are set to the proper install height and titanium retainers (SLP# 53104). Also, included are eight L92 offset 1.7 intake rocker arms and two L92 rocker arm pedestals.
408 cid short-block
with slps
oh i see .. so ill talk to the guy doing he final stages on the engine help me pick out a cam.. so other than that how bout the set up i have listed would it be a good 408 with the custom cam?
Hell yeah it will! I just did 497 RWHP with just a lil' MS3 and FAST 90/90 in my TSP 408. And there's more to be had, was breathing thru stock MAF and super rich!!! Will be swaping the MS3 for a Texas Giant soon (20~25 RWHP more right there) there's 520 ~ 530 RWHP in the car, just need to find those last few HP.
Took a ton of fuel out of the VE table but ran out of dyno time. Tuned by Jeremy Formato.
497 rwhp is this a m6 or a4? damn those are the numbers im lookin for around 525 to 550ish on all motor.. and with a 200 shot hopefully in the high 600s loow 700s .. well let me kno the results when u do the swap.. how bout if u change ur MAF? u expect a lil bit more too?
M6, have replaced the stock MAF with a 85mm and looking for a 90mm Lid. Will also be adding 2 cutouts and the Texas Giant cam. Being at almost 500 already thru a full exhaust, conservatively those final mods should put it at 520 RWHP and maybe a little more.
Also running a Nitrous shot for ***** and giggles jetted for 150 Hp. Don't wanna go more 'cause of 11.5 CR your guess as good as mine what it'll do with that.
I'm looking at doing about the same thing now, but I'm thinking about a set of AFR 225 heads instead with a FAST 90/90. I'm already running a speed density tune, so I won't have the maf restriction. Otherwise, same setup. I like it.
how much of a shot of nitrous can i run with this safe side.. i was readin on texas speed that its capable to make over 800rwhp on nitrous...ANd say for future refrences if i want to do F/I would this be a good set up as well?
so what pistons should i run? but since im bring down the compression doesnt this mean imma be losing some hp o am i wrong:?
which one would these be alright to run
diamond -10cc
" " -15cc
or Mahle-12cc
diamond -10cc
" " -15cc
or Mahle-12cc
If you want to go forced induction, you need to have lower compression to get the most horsepower. 9:1 would be decent if you weren't going to get the FI yet, but were going to in the future. With nitrous, you can go with either high or low, better high due to running N/A on the street. Plan your build, then go with it, or you'll always be running in circles. Figure out what you want to do, FI/N2O/strictly N/A, whatever, then do some searches on compression ratios and figure out what static and dynamic compression ratios will work for you.
