Beehive VS. dual springs HP differance?
The reason they probably gained 40hp was because their dual springs were running into a harmonic that the beehives cancelled out.
But to get back on track, a lightweight small diameter dual can provide the same high RPM stability as a beehive and also allow you to sleep at night.
Talk to the owner of a beehive sprung motor after one of his springs break.....it aint pretty as the valve only has one way to go. The duals can break also but your safety net is the other spring still remaining.
Tony
Our 8019 dual made the same power till 6700 as a Comp 918 (the beehive gold standard at the time) and made slightly more power from there till 7000 where we terminated the test.
IMO, the right dual set-up can be as effective as a beehive design and while a dual spring doesnt guarantee against engine damage (you can still tag a valve with only one spring providing less pressure), you are far less likely to drop a valve which causes catastrophic engine damage....a bent valve is far less painful on the wallet.
Tony
PS....The worst performing spring of the test was the dual Comp design with the ovate wire. They work well with stock rockers but this test was conducted with Crane Gold rockers which made valve control a little more challenging due to the added rocker weight.
I've seen decent improvements on BBC's. Mostly because it gave them some more RPM. We also had a Super Stock that saw a big difference in his little 289 since he had another 800 RPM of valvetrain stability.. Ended up winning his class in the nationals tihs year..
Tony
I cant see how, if you have good valvetrain control, you could make that much more power
just with a single spring. Harmonics aside.
LOL
