Will I need new pushords w/ new H/C setup?
Regardless - someone mentioned to me that due to 230 duration - that I might need new pushrods. Right now, I have the stock length chromolly pushrods that I ran when I was running cam only with the XER 224/224 cam (only 2000 miles on them). Is this thinking right?
I have already spent enough money on what started out as a repair (why replace when you can upgrade right?) so I really dont want to fork out more $$$ unless I need to.
Ultimately, my concern is the safety of the motor so I wont skimp on something if it is recommended or needed but I have only heard "new pushrods" mentioned once - so I am just trying to figure out if that statement carries any validity.
Any input would be appreciated.
Milling heads, negates a smaller base circle. So, in essence, you are only .020" shorter than stock. Since they dont make a 7.420" pushrod, you can stick with the 7.400" length pushrods. Aaaah, the beauty of hydraulic lifters!
If you really dont care to learn, then thats okay too!
I guess that means if you are an M6 guy with hardened pushrods, Your getting the most from your cam, but you better not miss a shift!!
***taking hand and passing it quickly overhead***
