Are my compression figures right?
Old Feb 17, 2008 | 01:37 PM
Indiana Hawk's Avatar
Default Are my compression figures right?
2002 stock LS1:
PRC 5.3 2.5 heads
62cc combustion chamber
.40 cometic gaskets
TR 224 112+4 cam
If I were to do these mods I come up with SCR of 11.346 & DCR of 8.695. Anyone tell me if these figures are right, if not can someone correct them?
Old Feb 17, 2008 | 01:39 PM
noah89's Avatar
Is that an aftermarket hood on the car. Looks good.
Old Feb 17, 2008 | 06:09 PM
No, it's a stock firehawk hood
Old Feb 17, 2008 | 06:40 PM
405HP_Z06's Avatar
Old Feb 17, 2008 | 07:21 PM
jow02327's Avatar
TSP figured mine up to be 10.88 to one with the stock CC 5.3 heads and .030 cometic gaskets, i dont know if haveing 4cc valve releifs affect it or not.
Old Feb 17, 2008 | 09:56 PM
mochiles's Avatar
Yes it will.
Old Feb 18, 2008 | 12:03 PM
Originally Posted by 405HP_Z06
Hey, thanks for that. I think you've helped me out before. From what you figured the SCR is good but the DCR is a little high for pump gas, what do you think? Can you figure it with the DCR around 8.7 or 8.6? What kind of SCR would I have with that?
Old Feb 18, 2008 | 04:18 PM
HEMIETR's Avatar
Don't read too much into the DCR. You will be fine. This site preaches DCR. Its not that big of a deal. Read this: http://speedtalk.com/forum/viewtopic.php?t=7463
Old Feb 18, 2008 | 04:38 PM
405HP_Z06's Avatar
I agreee with HEMIETR concerning DCR. I post the approximate value because people ask for it. The cam you specify will be fine for 93 octane.
Old Feb 18, 2008 | 05:06 PM
I clicked on that link and it's asking for a user name and password. You got another one?
Old Feb 20, 2008 | 09:01 PM
Dave88z's Avatar
405hp can you check my compression? Sorry to hijack by the way.
408, 4.030, 4.00
64cc head
JE flat tops 5cc relief
.051 gasket
pistons .019 out of the hole.
Thanks man, where did you find that calculator. It looks a lot more detailed then
the one I am using.
Old Feb 20, 2008 | 09:21 PM
405HP_Z06's Avatar
408, 4.030, 4.00
64cc head
.051 gasket
the one I am using.
The calculator is from Performance Trends, Inc. Amazingly, it's called Compression Ratio Calculator.
Old Mar 12, 2008 | 04:47 AM
MLP00Z28's Avatar
Sorry to hijack the thread but what's the max DCR to use gas pump? I've been reading and some guys are afraid on running 8:1 or 9:1 DCR and I got 11.54 SCR and 10.124 DCR, I do not know if I calculated it incorrectly but 10 looks a lot to me. Hey Aaron, could you help me out? I'm just a pain in the *** I guess jajaja, thanks again you've helped me out before
I'm using 59 cc heads
3.903 flat wiseco 2cc valve relief
4.030 bore and .030 thick head gaskets
3.622 stroke
6.100 rods
0 deck height
TREX CAM @ .050
1.- Intake
duration 243.5
lift 108.3
valve closing ATDC 50.1
2.- Exhaust
duration 249.5
lift 111.5
Old Mar 12, 2008 | 07:55 AM
405HP_Z06's Avatar
3.622 stroke
6.100 rods
0 deck height
TREX CAM @ .050
1.- Intake
duration 243.5
lift 108.3
2.- Exhaust
duration 249.5
lift 111.5
Based on the specs above:
From a quick search, the Trex has an IVC of 76.7 at .006. There are many debated ways of calculating DCR and no one agrees upon the method or what the number really means. It's used alot on this site, but I don't put much stock into it.
My present combo is 11.31 SCR, 8.29 DCR and I have no issues.
Old Mar 12, 2008 | 10:00 AM
MLP00Z28's Avatar
Thanks bro and yes, I've got 76.7 in the cam card, it would not be so far from 75, well thanks a lot. I guess I'll have no problem if you dont.
Old Mar 12, 2008 | 08:36 PM
405HP_Z06's Avatar
Updated with 76.7 IVC event, lowered the DCR slightly.
Old Mar 14, 2008 | 11:38 AM
Can you run some more numbers for me?
stock ls1
64cc heads
stock GM mls gaskets
224/224 .568/.568 110+4 ICL 108
Thanks
Old Mar 14, 2008 | 07:52 PM
405HP_Z06's Avatar
stock ls1
64cc heads
Thanks
Old Mar 14, 2008 | 11:22 PM
I was wrong, that cam is on a 106 ICL not a 108. Don't know if that makes a difference or not.
Old Mar 19, 2008 | 12:02 AM
405HP_Z06's Avatar
The above calculation is correct for the 106 ICL. I calculated IVC based on 110 + 4 instead of looking at the 108 ICL in the first post. I made a mistake initially but it was correct in the end.
110 + 4 (106 ICL) = 64.5 IVC
110 + 2 (108 ICL) = 66.5 IVC
