MS3 or MS4 Daily Driver
Old Feb 25, 2008 | 06:07 PM
  #61
rocksws6's Avatar
Originally Posted by Fastback302
The curve between the pat g and the MS4 seem to be pretty close from 3.5K
up to about 5500 where the MS4 starts to really shine putting down around 20hp more till redline! I really didn't get to see what these cars do below 3,000 but that is where you just drop a gear and let that clutch hold on for dear life! Again seems like torque and horsepower are pretty close until about 5.5K! I guess the reason one would choose the pat g over the MS4 is the everyday driving around 2k to 3k, I would assume would be much smoother! Am I getting close to understanding this?!?! The everyday driving range is more importnat to me than 20hp in the last 1000 to 1500 RPM's!
Your looking at #'s there's alot of Magic Stick cars out there that stay right around 400 whp some don't even break it. Then you have chris with almost the exact cam I do and he put down 422 to my 397. The only way you can look at #'s is same dyno, same car. Do you see what I'm getting at?
If I had to guess the Magic Stick would probably make 5-10 more peak hp then the cam I'm running on stock heads. After ported heads and or a fast 90 the difference would likely be more substantial.
Old Feb 25, 2008 | 06:18 PM
  #62
chrs1313's Avatar
Originally Posted by rocksws6
Your looking at #'s there's alot of Magic Stick cars out there that stay right around 400 whp some don't even break it. Then you have chris with almost the exact cam I do and he put down 418 to my 397. The only way you can look at #'s is same dyno, same car. Do you see what I'm getting at?
agreed my car is pretty maxed out in all ways with intake and exhaust...but i agree ms3 might have around 5-8hp more...
oh and i am 422hp ha
Old Feb 25, 2008 | 06:26 PM
  #63
JayplaySS's Avatar
Moderator
You guys with driving issues and lower MS3/MS4 numbers...
What is your milage and did you change the chain or check for too much slack? When I installed my 233/230/605 TSP at 80K, my chain was stretched to the extreme so I changed it. I am just trying to justify variables.
  #64
rocksws6's Avatar
Fixed it. Your car made great power. That's damn impressive.
Old Feb 25, 2008 | 07:48 PM
  #65
NC98Z's Avatar
Now the MS4 is ground to be more street friendly than the MS3. And I've got to admit I've never rode or drove a Camaro with a MS4/MS3 in a M6 car. But in an A4/Stall convertor car you can fire it up. Put it it in drive and from then on you have the option of taking off like a preacher going to church or the devil heading home. Your car will pull itself around at will at idle and I love mine. But to each his own.
Old Feb 25, 2008 | 08:29 PM
  #66
Oh4GTO's Avatar
Ive been running around with the MS4 for over a year now. I love it overall but there are times where it really pisses me off. On the highway in sixth gear it does not want to maintain speed. It starts slowing and if I put a bit more throttle into it, it starts knocking. Traffic driving really sucks. You have to slip the clutch a lot. The cam definately bucks under 2000 RPM with light loads. With heavier loads its better but Id rather down shift than lug it. I have no problem starting it or idling. Jeremy did an awesome job tuning it. We spent about 7 hours on it. I had a TR224 cam before the MS4. Even though the numbers were nothing special with that cam, the way the car drove was amazing. So much low end that I didnt have to downshift on the highwya all the time or to beat a red light or to pass someone.
Old Feb 26, 2008 | 04:48 PM
  #67
Fastback302's Avatar
Okay we just got a lot of MS4 lovers to post.
I really think that the heads will stay stock on my car ....maybe a polish if it is worth it, but again I only have 40,000 miles and would like to get the full value out of my motor! Without changing major components, like heads or the short block! And I really dont want to launch to hard on my little rear end! By the way what was GM thinking on that one? 10" HAHA
So since I know I want to keep stock heads, I think that the gains from a pat g cam would be enough, but I haven't heard from anyone on how well it drives around town! I hear different stories about the MS4 but nobody talks about the driving characteristics from the pat g or 224 cams.
Old Feb 26, 2008 | 06:12 PM
  #68
Reject's Avatar
oh there is **** load's of info on those cams, they are basically beginner cams, everyone starts on those cams and depending on where they want their car to go get larger, or stay with that one. search up on the tr224, back in the early years that cam was considered "HUGE" but it's a GREAT daily cam, you WILL be happy with that sized cam for a daily
Old Feb 26, 2008 | 08:25 PM
  #69
Oh4GTO's Avatar
Fastback I posted on how it drove around town. Read the full post.
Old Feb 26, 2008 | 08:29 PM
  #70
chrs1313's Avatar
drives amazing around town...actually use less throttle with all the extra torque for a given speed...kinda nice can almost idle once up to speed around 30-40mph just a hair more throttle...it really drives nice like a 224 cam that my dad had in his car before the ms3...check some of my other threads i know i talked about it somewhere...mine is a predator cam but basically the same as patrick g...i just wanna give him the credit...
Old Feb 27, 2008 | 10:35 AM
  #71
Camaro396's Avatar
**** it. Where do you live. Ill just drive my junk there, and take you for a ride. You can see how a MS4 car runs.
Old Feb 27, 2008 | 11:03 AM
  #72
yyz28's Avatar
Thumbs up
It is really all about the tune.
I have an MS4 and a Yank 4000 stall, and the car is fine for daily driving. I have virtually no surging and the bucking on deceleration is almost non-existant.
You can dial ANY cam in for daily driver use if you have a good tune.
Rumpity-Rumpity...
...oh, and it put 430 to the rear wheels through the Yank PT4000.
Old Feb 27, 2008 | 02:09 PM
  #73
Reject's Avatar
really interested in which way the OP will go
yyz28 the sig is way over sized, need to correct it before infraction/editing happens
Old Feb 27, 2008 | 02:14 PM
  #74
Reject's Avatar
and just for ***** and giggles
https://ls1tech.com/forums/generation-iii-internal-engine/683617-do-any-shops-market-small-cams-anymore-why-not.html
Old Feb 27, 2008 | 02:19 PM
  #75
wg871's Avatar
it just depends on how tolerant you are
Old Feb 27, 2008 | 08:07 PM
  #76
hammertime's Avatar
Man, I hope you haven't changed you gears and converter yet. Toledo, OH to St. Charles, MO = 507 miles one-way.
Old Feb 27, 2008 | 08:13 PM
  #77
02TransAm/Batmobile's Avatar
Neither. The MS3's and the MS4's don't provide me with the low-end torque I am looking for. Look into the G5X3's.
Old Feb 28, 2008 | 12:36 PM
  #78
Originally Posted by reject
Wow this is a lot of awsome information...thanks for pulling this up!!! I definatley dont want a big cam after reading this!!!! These are all moderators posting reality and the main reason why everyone in jumping on the bandwagon of big cams is because of the old saying "supply and demand!"
New comers want the biggest and badest and the vendrs want cash..plain and simple, however I have read that most lendors will try to talk sense into you but ultimatley they just supply for the demand!
Old Feb 28, 2008 | 01:36 PM
  #79
Reject's Avatar
woops lol been trying to get them to sticky that for a while, hopefully one day...
Old Feb 28, 2008 | 05:16 PM
  #80
Crap I have 843 heads...is this bad compared to the 241's....if I plan to go with a tr224 or tsp228 cam would the fact that I have 843's hurt the performance....would you put springs in a 843 or spend the money to polish them or should I just buy LS6 heads or better? I have a funny feeling I am going to spend more money than I thought...but I have that horsepower bug bitting me and I want to do it right the first time...car only has 40k miles
