1.85 comp cams rockers ls6 springs on stock cam
I bought some comp cam 1.85 rockers and was wondering if i could use yellow ls6 springs 570 lift and comp cams magnum stock length 7.4 pushrods that I have laying around allready with them.I have a stock cam in my 2000 ls1 camaro I calculated the extra lift to put me at around 541.94 lift by dividing my gross lift intake/exhaust by stock rocker ratio 1.7 and then multiplying that number by my new rocker ratio 1.85=541.94. i just want to double check and im not sure on the pushrod length and i dont really want to buy some new springs since I allready have some.let me know what you guys think hopefully im right and my parts work for this setup and if you guys have any comp cam rocker arm instructions please let me know thanks.
Pushrod length should be the same, im in the almost same boat as you. I bought some Harlandsharp 1.8 rr's and with my hotcam at .525 and a 1.8 rr my new lift is .556 and I am getting some patriot gold springs from Speedinc because I didn't like the way they were sounding while I was getting a retune. like I always say upgrade and never replace
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Its actually less sir
stock 2000 cam is:
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
.496
/ 1.7
.29176470588235294117647058823529....
X 1.85
.53976470588235294117647058823529
So yea you should be good with Ls6 springs!
You wanna buy mine?
only used last summer about 5k miles!
pm me, here's pics
![](http://i214.photobucket.com/albums/cc127/litle8/IMG_3531.jpg)
![](http://i214.photobucket.com/albums/cc127/litle8/IMG_3530.jpg)
]the guyz at straightline can verify that my springs are GOOD!
who cares if its just 570 he is fine......i didnt mention adv duration of my cam is 286 and it is fine on those springs my rev limiter is set at 6600 and the car sees it alot....ls6 springs stock pushrods titanium retainers......i spray a 150 shot and spin it to the moon alot.....i see NO problem with what you are gonna do at all....
I just want to give him the RIGHT info and not an "I heard" or "my buddy" typeof info that is all. I never said there was anything wrong with the springs he's going with.
Dont forget to upgrade the Pushrods they are only about 100bux and are a must in my honest opinion. free shipping from Speedinc!
CC7955-16 Chrome Moly Pushrods 7.400 (Stock Length) $114.99
http://www.ls1speed.com/cont.cfm?cid=C0000153
Goodluck and keep us posted!
