Fluctuating oil pressure problem
90k miles and im about ready to do a cam swap and yes i have a new ls6 ported oil pump. The car doesnt seem to lack ANY power and there is no knocking. I'm going to change the oil and filter today oh and its the stock sending unit on as well. Also another problem I'm having is sometimes when i hit a bump my guages go crazy, the service engine light flickers, the ASR light comes on and i cant turn the traction control back on and the car will for that moment seem like it misses then in like a few seconds everything comes back to normal WTF is goin on?
. Just tightened em back up and no more problem and the oil pressure guage doesnt fluctuate while driving but when coming up to a stop light until I completely stop as soon as i push the clutch in it will rev down to almost 500 rpm and go to about 20psi then once i stop completely it idles back up to normal right at 1k to 1100 rpm and just under 40psi hot. I also changed over to penzoil platinum 5w-30 today and didnt have much of a choice other than to use a fram oil filter and now at cruising speed its at about 45psi and will jump more at higher rpm. So what do u guys think is causing my idle issue when coming up to a stop? Trending Topics
Also.. If I'm stopped and turn the wheels.. it will make my rpms drop a bit when the power steering kicks in.
Any ideas?
