Anyone seen a 32V LSX head?
Old Mar 26, 2008 | 10:02 PM
camaro98z28's Avatar
Default Anyone seen a 32V LSX head?
http://www.araoengineering.com/LSX.htm
ARAO Engineering has just introduced the 32 valve LSX bolt on heads for the LS-2 and LS-7 motors. These heads are a direct bolt on and use all standard intake and exhaust manifolds, exhaust headers, pistons and standard camshafts. Compression ratios can be set by just flycutting the heads from 10:1 to 12:1. The valves are operated by the standard cams, lifters and pushrods. This is done through shaft mounted needle bearing rockers, that operate 2 valves with one rocker arm.
Old Mar 26, 2008 | 10:08 PM
c5_ls1_6spd's Avatar
Holy Crap 8grand for a set of heads
Old Mar 26, 2008 | 10:23 PM
Funkster's Avatar
Old news, apparently this guy has been dicking people over for quite some time. There is a few guys here that are strongly opposed to him and his business.
Old Mar 26, 2008 | 10:29 PM
MeentSS02's Avatar
Kleeborp the Moderator™
If you had done a quick search, you would have realized that, indeed, a lot of us have seen these heads. Waste of time and money.
Old Mar 26, 2008 | 11:05 PM
SSCamaro2000's Avatar
Thats wierd....
Old Mar 26, 2008 | 11:12 PM
WhiteStripes's Avatar
Yeah, if it were a legit company I'd think it'd have a bit better of a web page.
Old Mar 26, 2008 | 11:16 PM
got-a-ls1's Avatar
$8000 for heads or $8000 for a fully supported turbo or supercharger setup. hmmm ill take the forced induction.
i would like to see a face off of these heads vs ported ls7's on a dyno though. They claim pretty high flow numbers....
Old Mar 26, 2008 | 11:26 PM
NemeSS's Avatar
long thread before about these heads.
more cons than pros
Old Mar 26, 2008 | 11:30 PM
99mongooSS's Avatar
they are bull ****! A guy who came to our shop had a set of these on his small block chevy race car, they fell apart by the end of the race season. He ended up going to a set of AFR's and only lost 37 hp from the 4 valve heads. Its been three seasons and he hasnt had to touch his heads.
Old Mar 26, 2008 | 11:32 PM
b00sted's Avatar
Pretty cool. But I'd rather run AFR's and make up for the rest with a small dry kit.
Old Mar 27, 2008 | 08:27 AM
b0pric01's Avatar
yeah this has been beat to death in another thread somewhere. overall the consensus was that the extra gain isnt worth the assload of money and complexity you have to deal with. if you are fckin loaded and want to try it, go for it.
Old Mar 27, 2008 | 09:05 AM
BlackScreaminMachine's Avatar
Internet Mechanic
In theroy had the motor not been LSX based and had crappy stock and even aftermarket flowing heads, it would maybe something to consider but in reality whats out there w/ 2 valves is still too much for stock and most of it was designed with aftermarket/larger cubic inches in mind
