Lifter question
Now....hypothetically of course, lets say I spin the cam, knock the lifters up and take the cam out. If a lifter falls does the "lifter cup" catch it or does it fall and get all out of whack? If a lifter falls with the cam out, can I stick a magent in the pushrod hole and pull the lifter up as I reinstall the cam or does it not work that way. I have one (1) pen magent....just trying not to buy 15 more.
Thats how the lifters sit in the motor. the plastic holds the top part of the lifter, where the push rod goes in. By spinning the cam, you push the lifters back into the cup and it is supposed to hold it. Honest i wouldn't trust it to hold it. I'm not sure bout the tooling use to hold up the lifters, because i was changing my heads when i did the cam. here are some pics of my motor. If the lifter drops, I THINK it is going land on the crank or fall down into the oil pan. Hope this helps
I guess what I am trying to ascertain is if the lifter cups just keep the lifters aligned or if they actually hold the lifter from falling too far.
