Mega Death Cam !!!???
Old Apr 24, 2008 | 07:45 PM
COPOSS's Avatar
Question Mega Death Cam !!!???
Has anyone have or know some one.With the Mega Death Cam. 244/242 .612/.610 on a 112 LSA. On a LS1 SS. Youtube has GTO's and Z06's and two GTO LS1's.They say good driveabiliy on one of the 6.0 GTO's. And seem on the other cars. I'll be using AFR heads. Kooks and 90 FAST. All input will be great Thanks !!!!!
Old Apr 24, 2008 | 10:45 PM
99mongooSS's Avatar
sounds like its nothing but a trex intake dur. mixed with the ms4 exhaust dur. doesnt sound like anything outta the ordinary...Do you know what lobes its using (I.E., XER,XFI, ect.)? Is it made by comp, crane, lunati?
Old Apr 25, 2008 | 12:29 AM
5w20's Avatar
loss of low end
Old Apr 25, 2008 | 12:31 AM
COPOSS's Avatar
no i don't know the lobes. I did some more looking around and this cam seems more of a upper end cam on the RPM.
Old Apr 25, 2008 | 12:44 AM
ssduane's Avatar
I used to run a cam that size duration, with less lift in a 327. Solid lift also with 210cc runner heads. Streetable, yes with high compression, but like 5w20 said, loss of low end. Thing felt like a 2 stroke bike though powerband wise, 3500 rpms it would pull like a ****.
Old Apr 25, 2008 | 09:51 AM
ArklaTexan's Avatar
I was the first GTO that HPE installed this cam in, and it is an LS1. There is no loss of low end! I would make sure your PTV clearance is enough with the new AFR. I went with Patriot LS6 Stage II 59cc heads with welded chambers because they maintained stock head tolerances. This is a comp cam and it peaks at 6350rpm on my setup.
Old Apr 25, 2008 | 10:01 AM
ONEBADWS6's Avatar
You gain clearence with a AFR head do to the thicker deck.
Old Apr 25, 2008 | 10:05 AM
ArklaTexan's Avatar
You should be pretty close to the numbers in my sig with that setup, only difference is our heads.
Old Apr 25, 2008 | 10:58 AM
lilbuddy1587's Avatar
The cam is too big for what you're after...You WILL lose low end while puttign around town. Even @ WOT the car is going to feel like a dog until about 4-4.5k RPMS unless you're running 4.10 gears or better.
Old Apr 25, 2008 | 12:19 PM
COPOSS's Avatar
I have in mind a Comp XE-R grind 228/230 LSA 114 or a 112. Or a 232/238 Lunati Voodoo. I have 3.73's in the car and 4.10's in the box new.
Old Apr 25, 2008 | 12:34 PM
ArklaTexan's Avatar
Wow, I didn't know my car feels like a dog around town. If I punch it I am gone, there is no loss of torque no lag! You act like it is a huge turbo that takes time to spool.
Old Apr 25, 2008 | 12:43 PM
b00sted's Avatar
But then lose some due to the larger valves.
Old Apr 25, 2008 | 02:03 PM
99mongooSS's Avatar
There is not going to be that much loss... My MS4 didnt have that much loss of low end, in fact from 2800-6800 it yanks hard.
