Most powerful cam for Ls1 with power under the curve???
I've got an 04 GTO and so far I'm looking at.....
Trex
Vindicator
HPE S-Cam
HPE MegaDeath
LG G5X-2
The car is an M6 if that helps any.....I want the most HP and TQ numbers I can get out of it can only....For now I will be doing coated LT Headers, true dual mandrel bent 3" x-pipe, cold air, and a tune of course.....shortly, i will be getting a set of 243 heads, but they will be stock.....I'm kinda on a budget here.
Trex
Vindicator
HPE S-Cam
HPE MegaDeath
LG G5X-2
Mainly I'm aiming for 400+rwhp and would like to have a great torque range to go along with it......I've got a GTO, so I've got alot of weight to carry around! Lol.
LOL if your aiming for 400+, 1st off you def don't need that big of a cam and 2nd off a TREX cam will put you over 500+ in many cases. I've been in a car with that cam and its massive, a MUST tune cam. With a full exhaust, intake, trex, and a good tune you should easily be over 500+rwhp, those are 10second cams. If you want 400 Id look at something as small as even a 224 or 228 with a full exhaust people usually hit 400 give or take a few 10hp.
You have no idea what your talking about.
WTH??? I really wonder where some ppl like this dream up there information sometimes. There is no such thing as a "10 sec cam" or an "11 sec cam" etc. No cam only will net you 500RWHP, you have no clue what your talking about, and besides the post isnt about peak HP he is asking about under the curb power. I would probably suggest something like the TR224 or a 230 cam.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
1 Post
maybe I can help. I have a fully modified c5 frc that put down 490 rwhp 445 rwtq. I am running afr 205's milled to 59 cc , g5x3 vII cam, ported Fast 90, pro longtube headers, ud pully and ewp. The cam I have with the supporting mods made 360 rwtq at 2800 rpms. Then from 3000 it starts climbing fast. I have tons of torque everywhere. Talk to LG Motorsports about your build and get one of there cams, or have them do a custom one for your application. Good luck.
BTW The guy telling you about 500 hp cam, etc etc, I don't think I'd trust his advice.
I too have a 04 gto. my first cam was a comp xr281 and was very happy with it. ran it with stock heads and long tube's. ran the 918 spring's and wound it to 6800 all the time.
Then went to a tr224 when i put 59cc afr's on just due to ptvc worrie's. I hated that cam after the xr281
Then went to a xer 281 and i was pretty happy but now going to a xfi/xer 242/244 cam
My car is a auto but i don't think you can go wrong with the xr281 for the first cam it is 228/230 @.050 .571/.573 112+2 xr lobe's so not too much valve train noise
mike
mike
TR224 or a 224/228 if you want to stick it in there and make good power even without a great tune. You can get more up top with a bigger cam, but if you're not into racing I would personally pick the above and let your valvetrain live a little longer. No need to go crazy on the cam for a primary vehicle.
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
![Nono](https://ls1tech.com/forums/images/smilies2/nono.gif)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
