Well, found my misfire problem... It's the piston!
I can see needing the forged set up just in case you run boost in the future, but n/a sounds almost worthless. I could be wrong since I'm still new to the LS-world (10+ years building Mustangs), but no amount of normal n/a HP should ever give your stock short block any problems as long as your tune is safe and have enough fuel.
