Changing the rear main seal
Old May 12, 2008 | 08:47 PM
Ilikeppie's Avatar
Default Changing the rear main seal
So i got the tranny out of the car to change the clutch and i was wondering what all it would take to throw a new rearmain seal in while i was in there?
Old May 12, 2008 | 08:51 PM
07gsxr750's Avatar
easy, after you get the flywheel off, take a little pick or carefully with a small flat head screwdriver pop it out, becareful not to scar the crank up if using the screwdriver, then carefully pop the new one in, just remember to view the depth that the old one sat at before removing then position new one at same depth.
Old May 12, 2008 | 09:27 PM
Ilikeppie's Avatar
alright sounds good i wasnt sure if i had to drop the oil pan or anything so would it be worth it to change it out while im in there even though its not currently leaking?
Old May 12, 2008 | 10:09 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
As the old saying goes
"If it isn't broke, don't fix it"
Old May 12, 2008 | 10:21 PM
twitchtwice's Avatar
true but how often do you have the engine apart to put in a new rearmain seal?
i say do it while its off.
Old May 12, 2008 | 10:30 PM
99ls1bowtie's Avatar
change it if you think its necessary. but the thing is, there is a better chance of installation error (being you never done one) and it leaking, than the old seal naturally breaking down and leaking.
Old May 12, 2008 | 11:20 PM
Ilikeppie's Avatar
this is true too
Old May 12, 2008 | 11:42 PM
unually the only time you see a rear main leak (other than a high mileage car i.e. 120000+) is if the pcv system is not working properly. you will probably be alright not changing it
Old May 13, 2008 | 12:18 PM
Ilikeppie's Avatar
sounds good i will inspect it better and if all is well ill just leave that sob in there
Old May 13, 2008 | 07:00 PM
good luck to you
Old May 13, 2008 | 07:12 PM
Ilikeppie's Avatar
Thanks
