Anyone heard of destroking an LS this much?
I really want to go the nostalgia route, but using an all aluminum high rpm LS motor destroked to 283 cid to put in this 'streetfighter' style '55 below.
I was told GM prototype class race cars ran 300 cid using Sonny Bryant cranks. Any suggestions on design features this motor should have are appreciated. While the car will see time on road courses, I need the motor to be completely streetable. The car will be lightened also.
Thanks,
Skip
Thanks,
Skip
![](http://i87.photobucket.com/albums/k156/wnyjazz/Badd55%20big%20pics/55bigbaddbluewhiteredcailpers.jpg)
I've seen one destroked to 302 before. Lemme see if i can find it for you.....
Here you go
http://www.ttspowersystems.com/articles/7/index.htm
Here you go
Hmm...simple idea here to put a 4.8L crankshaft into a 6.0L. A stock 4" bore makes a 5.4L 329ci motor and a .030" clean up puts the displacement at 333ci. I'm not sure of any specialty crank for really short throws but that 329/333 would be one helluva motor on your hands. It wouldn't make any power down low and would require quite the camshaft and valvetrain mods, but if you matched the ring and pinion in the rear end right, it could be a fun little motor in that '55.
But I have thought about this for months and I really want the challenge of using the cubes the old racers were limited to during that time and see what we can squeeze out of a 283 with all the new technology.
It may not make any sense to anyone but me
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Skip
Thanks,
Skip
Thanks,
Skip
What kind of power are you looking for? How much do you have to spend on making a 4.6L (283) LS engine work? If you are looking for much over 400 fwhp, it won't be cheap and you'll need some expensive parts.
The 5.0L (305) Daytona Prototypes use the stock 5.7L bore (~3.90) and a stroke about 3.20. The heads are LS6 based with some killer porting. They are rules limited to about 7100 so I expect power peak is right about 7000. They are making well over 500 fwhp, but they probably rarely get under ~4500 rpm while racing.
Your problem with making power with a bore smaller than 3.90 is the heads.
The least expensive way, as pointed out would be to use a 4.8 (293) which would equate to a .060 over 283. If you want to be PC (Period Correct
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If you wanted to make the 4.8 run, you would need to get the 4.8/5.3 heads ported to work with the 3.78 bore. That is possible, but probably not done as often as 5.7L heads. BTW, are you thinking carbed intake? Done correctly, I think 450 fwhp in a streetable 4.8 (293) LS is doable.
This could be a fun project!
Jon
Why not do a wellmatched hyd-roller cam and TFS heads on a 4.8 block. Weight balance shouldn't be affected that much and should have good mid/upper rpm range power to go with a well setup drivetrain. IMO
When you destroke, you can twist the engine out of the frame. Like someone said, nothing down low, until you get the RPM's up high.
I have a little 283 project now with a 67 Impala.
I believe the racers in the mid 50's beat Chevy to the punch and bored out their 265's to get 283's. The 283 was so popular with tri-five racers as we know so I'm period correct enough I think
I'm looking for 500hp.
I also thinking of using a hand fabbed cross ram manifold like the 302 Z's with dual throttle bodies. Plus I really like that air cleaner on the dual quad Z-28's.
I probably will resell this car within the 1st five years so I have to think about how things look more than if I was just going to tinker with it for years and years.
So yes more money spent upfront but I believe I need something unique so when I go to sell it it will stand out.
Kalgorn, great looking '99 Z.
Destroking IMHO is done for several reasons i.e. when the motor is too big for a racing class, like in the late 60's the Trans-Am series Pontiac destroked a 400 to 303 cid. They just didn't spend the money to make it work from what I've read.
Its done when the motor needs to live in a high rpm range. Or when someone just wants it to live in a high rpm range, like me. Sure I could drop a 572 crate motor in the car, but that is not the effect I'm looking for.
As a kid I grew up reading Hot Rod stories about racers and their screaming 283's in Tri-Fives.
So I know know it will be more money and a bigger challenge but that's ok.
Oh I know.
IMHO if you say to someone 'that's a 301' when they are looking under you're hood at the motor, I think you'll get a blank stare.
If you tell them 'it's a 283' period... I think you get a much more favorable response.
But I do think we may see more 'tribute' LS 302's being built since that is such a respected displacement.
If I was doing a 1st gen Camaro, absolutely I'd do an all aluminum LS 302.
Skip
Skip
I agree it would be.
It may not make any sense to anyone but me![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Skip
Skip
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
PS Screw that cross ram intake and carbs..find yourself some Hilborn injection and do it right!!
As far as the cross ram shown here, the runner length isn't all that far off the LS series intakes, so one could be fabbed which both looked good and made the power you want.
FWIW, the first 5.7L engine used in the GM Racing Cadillac CTS-R had a 7L LS7 bore (4.125) with a 4.8L stroke(~3.27). It initially ran to 7900 but after one race it was mandated to about 7100 max rpm so the DOHC competition could keep up. The crank in the race engne was NOT a 4.8L production crank.
![](http://www.camaro-untoldsecrets.com/images/gif/crossr5.gif)
![](http://www.camaro-untoldsecrets.com/images/gif/crossr9.gif)
I'd either call a built 4.8L a ".060 over 283" or just fib a little and call it a 283. It will save you $3-$5K and 3-4 months in the build.
Good luck with you car.
Jon
