URGENT: middle of cam swap found problem
Could it just have been a bad cam? The lifter surface is fine all the way around.
The rest of the engine is clean minus normal stuff, oil in the engine was used but also clean and half clear.
Is it a bad idea to go ahead and put in the new cam or buy head gaskets and pull the head and hope I can find a lifter here in BFE?
Here are some pics:
Same thing but not as bad on the first lobe past the 3 main bearing as well, but nowhere near as bad. Can't roll that lifter to check the whole surface but what I can see also looks smooth.
It is probably the spring that is not handling the valve events as well as possible and so the lifter is beating the **** out of the cam. I had to replace my springs (one actually broke in 2 places, the inner small spring), valve seals, keepers, and locks.
Anway...my $.02
We have the heads off, upon close inspection it looks like the lifter does indeed have some bad spots
people here are kinda dumb about this stuff, are the head gaskets the same as truck ones and how can I tell what is what if they are not...the guy my dad talked to at the parts place seemed confused by the concept of LS1 so I hope they ordered the right stuff
Just replacing the lifters will not guarantee a complete fix, it might solve your problem for now, but not in the long run. (when it comes to a high-performance engine...the "long run" may not be that long!)
Check everything, keepers and locks are cheap insurance...valve seals too.
$.02
Should be able to compare part numbers or....you can always lay them on the block and make sure the holes all line up. Bore is same size and all...
to the op, i'd pull the heads and replace the lifters. obviously the valvesprings will be replaced, as well as the cam. maybe look into an oil pump if you haven't already. that looks like a lot of wear on the cam. what do the cam bearings look like?
the pictures I took with macro mode, the low lighting makes the wear appear more shadowed, they don't look nearly as bad in person and feel smooth as glass
just sucks this was an unforeseen expense is all, $50 for lifters, $50 for head surfacing, and $50+ for head gaskets...oh well, better than losing an engine with a brand new $320 comp cam after 100 miles
If your going to pull the heads, why not shave them down and bump compression while your at it.
